http://www.ebay.com/itm/Ford-Other-Pickups-F-600-/231701879535?forcerrptr=true&hash=item35f2821aef&item=231701879535
BIG truck.... 330 CI motor!?!?!
You would think Ford had a bigger motor they could put in there in 67. I am sure there is a lot of gearing involved, but still. Seems like it needs a LOT more motor.
aircooled wrote: BIG truck.... 330 CI motor!?!?! You would think Ford had a bigger motor they could put in there in 67. I am sure there is a lot of gearing involved, but still. Seems like it needs a LOT more motor.
i feel like this was a common practice back then. like dean1481 said some trucks like this (and bigger) would have the straight 6 in them. From what I've seen the solution they had back then was crazy high (numerically) rear gears and a giant radiator. it would pull anything, just not fast.
That is a big motor for the time. I had a C-60 Chevy that came with a straight 6. My father's last gas soda truck was a GMC with the 366 big block as an option.
I guess we will know in 5 days and 7 hours if you will be bringing that home since it is located only 2.5 hours south of Gainesville.
I can't be the only one who didn't see who started this thread, and thought about a Formula 600 car.
alfadriver wrote: I can't be the only one who didn't see who started this thread, and thought about a Formula 600 car.
You aren't...
So. Does this one have a sketchy rear frame extensions for the spring hangers or what......
To notch fab work. http://www.ebay.com/itm/Ford-Other-Pickups-CUSTOM-BUILT-6-DOOR-4x4-F650-SUPER-TRUCK-MUST-SEE/291567722859?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150805074509%26meid%3D1c72c48eb6f24071925b828c336cb38f%26pid%3D100010%26rk%3D21%26rkt%3D23%26mehot%3Dpp%26sd%3D231701879535
Also. what rating do you think that tow hitch has? 4K?
