93EXCivic
93EXCivic MegaDork
3/20/13 12:25 p.m.
The passenger seat on the Scirocco is a Jegs seat like this one.
I am assuming the belts of a 5 point harness from the bar are supposed to go thru the slot in the back of seat but doesn't that put the belts awful low and close together.
GameboyRMH UltimaDork
3/20/13 12:28 p.m.
Yeah there's no way those slots in the seat back are for belts.
ransom
ransom UltraDork
3/20/13 12:29 p.m.
I don't think so either. If the belt comes in through a slot and turns upward to go over your shoulders, that'll compress your spine in a frontal impact.
93EXCivic
93EXCivic MegaDork
3/20/13 12:41 p.m.
So do I just hang them lose when not in use?
z31maniac
z31maniac PowerDork
3/20/13 1:14 p.m.
No, you need a different seat.
3/20/13 1:17 p.m.
Yep, looks like this one's only designed for a 3pt (which makes you wonder what the hole in the seat bottom is for). If you just put the straps over the shoulders of the seat, in an accident they'd be pulled to the sides.
93EXCivic
93EXCivic MegaDork
3/20/13 1:19 p.m.
GameboyRMH wrote: Yep, looks like this one's only designed for a 3pt (which makes you wonder what the hole in the seat bottom is for). If you just put the straps over the shoulders of the seat, in an accident they'd be pulled to the sides.
Could I just run a lap belt then or the stock seatbelt?
3/20/13 1:20 p.m.
Yeah a lap belt or stock 3pt should be fine with this seat.
93EXCivic
93EXCivic MegaDork
3/20/13 1:24 p.m.
GameboyRMH wrote: Yeah a lap belt or stock 3pt should be fine with this seat.
I am assuming the stock 3 point is the best thing to use for autocross.
z31maniac
z31maniac PowerDork
3/20/13 1:34 p.m.
Yes, unless you plan on taking the car on track with an instructor/passenger. It's usually required for the passenger to have the same saftey equipment as the driver.
WilberM3
WilberM3 Dork
3/20/13 1:34 p.m.
the XJ-R uses one of those for a drivers seat. it's using a 5 pt harness without the sub-strap for a 4pt configuration. the seatback holes are probably just for molded in strength and maybe some airflow? the shoulder straps go over the seat to a harness bar i built, which you'd need to properly locate the straps in relation to your shoulders.
WilberM3
WilberM3 Dork
3/20/13 1:36 p.m.
that's of course for autocross only like that. if it ever gets developed into a trackday toy it'll get proper seats and 5 or 6 pt setup.
93EXCivic
93EXCivic MegaDork
3/20/13 1:41 p.m.
Oh if it goes on the track there will be a significant upgrade in safety equipment.
wbjones
wbjones UberDork
3/20/13 8:01 p.m.
I used a 3 pt when a-x'ing for several yrs ... when I got a car to do track stuff with also and switched to a 6 pt, I found it was of some benefit while a-x'ing also
YMMV
irish44j
irish44j UltraDork
3/20/13 8:30 p.m.
Use a 3-point and get a CG lock.....
CGLockRacer
CGLockRacer Dork
3/20/13 9:15 p.m.
irish44j wrote: Use a 3-point and get a CG lock.....
Thanks!
wgAm44B1s1YrOMe7hUXagQ2jfXfqXlD8TlWj8API3nDkp6S5v67EifHCfE6wBmB8
