92CelicaHalfTrac
92CelicaHalfTrac SuperDork
12/4/11 8:57 p.m.
Works now.
Taiden
Taiden Dork
12/4/11 9:00 p.m.
is that a RELAY?
irish44j
irish44j Dork
12/4/11 9:02 p.m.
heat is over-rated. Get a big fur coat......
porksboy
porksboy SuperDork
12/4/11 9:03 p.m.
Taiden wrote: is that a RELAY?
Not anymore its not.
fasted58
fasted58 SuperDork
12/4/11 9:10 p.m.
porksboy wrote:
Taiden wrote: is that a priceless RELAY?
Not anymore
Streetwiseguy
Streetwiseguy Dork
12/4/11 9:11 p.m.
Hmmm- is that the famous hung upside down under the leak relay?
Giant Purple Snorklewacker
12/4/11 9:11 p.m.
Was your heater recovered from a shipwreck?
pigeon
pigeon Dork
12/4/11 10:50 p.m.
In reply to fasted58:
I LOL'd. :D
92CelicaHalfTrac
12/4/11 11:11 p.m.
Yes, that IS a relay that up until this afternoon, was attached to my car. Errrrr... it was at least plugged in, i should say. Denso H300.
Heat IS overrated. The only reason i bothered to fix it was that i couldn't defrost my car in the morning, and the only time i could keep ice off my windows was if i was going highway speeds. Kindof hard to get up to highway speeds if i can't see.
Streetwiseguy, you're onto it. It took me MONTHS to just find this damn thing. Previous owner had relocated it due to FMIC setup. Apparently it now lived underneath may battery tray, upside down, and not actually kept in place by anything. Just stuffed in there with the rest of the harness. I didn't bother to check the other relay that's just hanging out down there, but i can't really think of anything else that doesn't (Now, "didn't") work.
Snorkle, the heater doesn't look like that.... but the relay did. I'm the car's 13th or 14th owner (the first 12 or 13 were dumb.), and it's been totaled a time or two.
For my next trick, i will rip apart my door to get my window back on track.
EvanB
EvanB SuperDork
12/4/11 11:28 p.m.
92CelicaHalfTrac wrote: For my next trick, i will rip apart my door to get my window back on track.
Maybe you'll find some cocaine in there.
92CelicaHalfTrac
12/5/11 8:40 a.m.
I wouldn't be the least bit surprised.
ValuePack
ValuePack Dork
12/5/11 10:40 a.m.
I don't suppose Per would let you recoup Challenge budget by the gram...
NOHOME HalfDork
12/5/11 11:42 a.m.
So you post a picture of a standard LUCAS relay...what is your point?
92CelicaHalfTrac
12/5/11 11:51 a.m.
ValuePack wrote: I don't suppose Per would let you recoup Challenge budget by the gram...
This isn't going on budget because the relay worked when i bought the car over 2 years ago. It's failed in the meantime. If the masses revolt over that, i'll put the 25 cents on the budget if it prevents accusations of cheating.
92CelicaHalfTrac
12/5/11 11:55 a.m.
NOHOME wrote: So you post a picture of a standard LUCAS relay...what is your point?
Well in light of that additional information, my point is that obviously those damn Brits shouldn't have touched my Japanese car!
Curmudgeon
Curmudgeon SuperDork
12/5/11 11:58 a.m.
Man, shoot that thing with WD40. It's got another 100 feet left in it.
Sky_Render
Sky_Render Reader
12/5/11 12:28 p.m.
92CelicaHalfTrac wrote: I'm the car's 13th or 14th owner (the first 12 or 13 were dumb.)
Logic dictates that this statement means if you were the 13th owner, you are/were dumb.
92CelicaHalfTrac
12/5/11 1:08 p.m.
Well, maybe. There's a 50/50 chance. I'm not exactly sure how many people owned it. Carfax shows 12 before me, but i know it passed hands without being registered a time or few.
And yeah... i might be dumb.
Brett_Murphy
Brett_Murphy HalfDork
12/5/11 2:42 p.m.
Can you deduct the profits from redistributing such things from the Challenge budget?
92CelicaHalfTrac
12/5/11 3:31 p.m.
Brett_Murphy wrote: Can you deduct the profits from redistributing such things from the Challenge budget?
I believe my recoup limit will have already been met, sadly.
Worst case scenario, i have the best (or worst, depending how you look at it) bribe for the judges ever!
oksbsIvmr0OnvTDts1tCjEGYf1vyidLwOE1GHVcKBemJ4n6pumB0Zx2ojMWoAS3r
