mthomson22
mthomson22 Dork
4/12/13 9:31 a.m.
Almost ready to test fire!!!
z31maniac
z31maniac PowerDork
4/12/13 9:34 a.m.
Nice!
4/12/13 9:36 a.m.
Needs more filter! But that's a nice clean install.
mthomson22
mthomson22 Dork
4/12/13 10:05 a.m.
Keith, I've got the Jenvey backing plate and large filter. The IAT sensor for the Megasquirt will mount on the backing plate.
These nekked pictures are strictly for showing off the goods
mark
kreb
kreb SuperDork
4/12/13 10:14 a.m.
Oh my! Mechanical porn. Are you sure that's allowed on a family site like GRM?
I wonder how much of that great sound will be left with the addition of filters?
GameboyRMH UltimaDork
4/12/13 11:55 a.m.
Looks good. What's that vacuum manifold you're using?
mthomson22
mthomson22 Dork
4/12/13 12:10 p.m.
GameboyRMH wrote: Looks good. What's that vacuum manifold you're using?
http://www.amazon.com/Blox-Racing-Surface-Mount-Vacuum-Blocks/dp/B007ZDR0DA/ref=sr_1_1?ie=UTF8&qid=1365786588&sr=8-1&keywords=blox+vacuum+block
Swank Force One
Swank Force One MegaDork
4/12/13 12:38 p.m.
The same thing is available for substantially less on Ebay, and that way you aren't supporting a sketchy vendor like Tru.
mthomson22
mthomson22 Dork
4/12/13 12:42 p.m.
I didn't have any issues with Tru. They were very friendly when I called them to explain about shipping to a different address. Plus I was a 'need next day UPS RED' kind of situation.
Swank Force One
4/12/13 12:52 p.m.
mthomson22 wrote: I didn't have any issues with Tru. They were very friendly when I called them to explain about shipping to a different address. Plus I was a 'need next day UPS RED' kind of situation.
Fair enough. If you need something quick, you need something quick.
If they have it in stock, they're fine to deal with.
jmc14
jmc14 Reader
4/12/13 1:32 p.m.
That looks really nice.
turboswede
turboswede PowerDork
4/12/13 2:48 p.m.
Oooh! Always fun to look at another person's ITB setup.
On my ITB'd car (79 Porsche 924) I've got a vacuum block like that with a vacuum line from each cylinder feeding into a single, larger line and then plugged into one end of the block. I found I still needed a substantial amount of restriction in the MAP line to the ECU to get a steady idle/reading.
I'm currently running MS1Extra in Alpha-N and modified code to run the Spark table (EDIS4 ignition) off of MAP to improve drivability (which it does) so that's why I found the extra restrictor important. MS2 is on my list to do, but now I have to replace the new clutch so the money I earmarked for the upgrade is going there :(
I think I'm going to relocate the restrictor so that it is between the vacuum block and the engine as I'm concerned the fluctuations might be impacting fuel pressure, I'll also add a vacuum canister to improve the power brakes, etc. I've heard that using a fuel filter in the line helps dampen pulses.
http://www.youtube.com/watch?v=4XgLYJVX3gQ
I thought I'd help In case this helps you setup your ITB's and ECU down the road :) Good luck!
mthomson22
mthomson22 Dork
4/12/13 3:03 p.m.
Thanks Turboswede!! The guy doing my install is hip to dampening the vac signal to the MS, and he has a plan.
Your car sounds good in the video!!!
turboswede
4/12/13 3:53 p.m.
mthomson22 wrote: Thanks Turboswede!! The guy doing my install is hip to dampening the vac signal to the MS, and he has a plan. Your car sounds good in the video!!!
Thanks :) That's only to about 4K, there's another 2.5K of rev range left in it to tune (wrings hands, laughs maniacally)
4/12/13 4:05 p.m.
+1 thanks Turboswede, I learned some more about the black magic of ITB vacuum systems.
turboswede
4/12/13 4:16 p.m.
You're welcome. I have to give thanks to the MSExtra forum and Google in general for providing the search results necessary to fill my brain with such wonderful knowledge :)
MIG welding tips make good restrictors and have a thread on one end already. Plus they are cheap and durable. So one could put one tip in each line from the cylinder.
Motorcycle guys use the MIG tips in their DIY carb balancing solutions which are basically 2-4 individual vacuum gauges mounted on a board and hung above the engine, each one connected to a single cylinder. Some use aquarium or small plumbing valves to make them adjustable.
mthomson22
mthomson22 Dork
4/12/13 4:53 p.m.
That's exactly what my installer/tuner guy suggested!!!
oldeskewltoy
oldeskewltoy Dork
4/12/13 6:06 p.m.
mthomson22 wrote:
Do I see a bore mismatch where the velocity stacks meet the ITB assembly???
4/12/13 9:20 p.m.
kreb wrote: Oh my! Mechanical porn. Are you sure that's allowed on a family site like GRM? I wonder how much of that great sound will be left with the addition of filters?
All of it. Been there, done that.
mthomson22
mthomson22 Dork
4/13/13 8:41 a.m.
oldeskewltoy wrote:
I will check that!!
freedomgli
freedomgli
5/20/14 11:35 a.m.
mthomson22 wrote: The IAT sensor for the Megasquirt will mount on the backing plate.
How is that working out for you? Are you experiencing any heat soak issues from the engine heat transferring through the throttles and the backing plate to the IAT sensor?
I've seen some very tidy setups where the IAT sensor was mounted to the air filter backing plate between the intake trumpets like you describe (see pic below) but I've been warned it may cause a problem with heat soak. On my car I'm planning on using a phenolic intake manifold gasket. I just don't want to drill a hole in my backing plate only to realize later the IAT sensor doesn't function well in that location.
5/20/14 11:44 a.m.
Looks awesome. Thanks for sharing.
fxUOq4rgGWausW3xDWYb03cOYtkLFM9l1paNRoToecqGvQPByWr79tgAAbyHRvts
