Teh E36 M3
Teh E36 M3 SuperDork
11/12/20 11:34 p.m.
Anyone have some dimensions for the bmw n52? I got a 62 Midget shell and would love to see if this can slot in. Otherwise, 2.0 mzr.
11/13/20 10:22 p.m.
In reply to Teh E36 M3 :
I can get some tomorrow if it's not raining.
Teh E36 M3
11/14/20 12:30 a.m.
Oh man thank you. Haven't heard peep and I'm itching to move forward.
Teh E36 M3
11/14/20 12:31 a.m.
Just make sure the height dimension is less than 24" and length less than 30" ok?
Haha
mikeatrpi
mikeatrpi HalfDork
11/14/20 3:37 p.m.
Well it's going to be close ... 06 330i with n52
11/14/20 9:43 p.m.
Dammit, I forgot. I'll check my 07 525xi tomorrow if it's not raining
wspohn
wspohn Dork
11/15/20 10:59 a.m.
I'd look at the 4 cylinder options that pose fewer packaging challenges.  Either the BMW 4 cylinders, Volvo 5 cylinders, or GM Ecotec (NA or turbo).  Or if you like rpm, an S2000 engine.
A Midget would require a pretty goofy looking bonnet hump to clear the front of the N52, I would think.
But never say anything is impossible - have you seen this one that someone managed to shoehorn a Jag straight 6 into (heaven knows what is left of the Midget chassis).
ProDarwin
ProDarwin MegaDork
11/15/20 11:02 a.m.
mikeatrpi
mikeatrpi HalfDork
11/15/20 1:52 p.m.
I can take more careful measurement if you like... This was a quick and easy check.  Let me know if you want anything more precise or specific.  What i measured was firewall to the front at 29 inches, crossmember subframe up about 24 inches,  and widest parts of manifold to manifold about 23 inches
Teh E36 M3
11/15/20 10:41 p.m.
The jag sprite was what gave me the bad bad idea to even look.
I posted in the stalker thread and on his thread on locostusa but haven't seen anything in a couple days.
thank you thank you for the measurements. I think the width is going to kill it. The angle may make the height ok but I think that the overall width might kill it. I'll take some closer looks with your measurements and get back to you all.
Teh E36 M3
11/15/20 10:43 p.m.
Btw - the other plan is mzr 2.0. It looks like it will fit fine. The sweet six soundtrack will be missed though.
Teh E36 M3
11/15/20 10:48 p.m.
Teh E36 M3
11/15/20 10:53 p.m.
So I can and plan to take out the heater shelf which sits next to the firewall. That's why I can do 30" fore and aft. Vertically I have 23" from bottom of the frame rail to the hood. I can get a little more with some very minor pan mods or a bash guard below the rail. Side to side I can clearance the top of the footwell with zero passenger impact.
this is way too close to call.
frenchyd
frenchyd PowerDork
11/16/20 6:31 p.m.
A Jag V12 is the same length as the Six cylinder. It's only 22 inches wide at the exhaust manifold, 26 inches high ( including either the carb manifold or the FI manifold  )  and 26 inches tall
plus it's 30 pounds lighter than the 6 cylinder used
frenchyd
frenchyd PowerDork
11/16/20 6:32 p.m.
In case you think it's never going to fit, I've got plans to make a A MGTD and use a Jaguar V12 and suspension
chandler
chandler UltimaDork
11/17/20 7:56 a.m.
French, I saw your name and knew exactly what I would find in this thread...
Driven5
Driven5 UltraDork
11/19/20 1:25 p.m.
What transmission would you use with the N52? Factory BMW setup? How wide is the tunnel back where the bellhousing would be located?
clshore
clshore Reader
11/19/20 7:02 p.m.
Oh, just go ahead and put an LS into it.
There used to be a Spridget with Chevy Small block that ran in South Florida SCCA (ASR) and ACALAM races.
You couldn't tell from the outside.
Teh E36 M3
11/19/20 7:55 p.m.
Oh Mr Frenchy- awesome idea but I'm not *that* crazy. I picked this up yesterday for a really good price.
Teh E36 M3
11/19/20 7:56 p.m.
I'd have gone bmw n52 whatever they hung from the back of it. A little bit of a long shot and really- with some work I could have gotten it in but the electronics and certain peculiarities of that engine scared me off. The mzr/duratec is light and sorted. And will be a big enough pain in the ass to make work.
mikeatrpi
mikeatrpi HalfDork
11/20/20 8:50 a.m.
Nice.  Smart choice.  Lets see the build thread...
frenchyd
frenchyd PowerDork
11/21/20 9:21 a.m.
You are right,  it's probably a much easier install.
Teh E36 M3
11/21/20 10:58 a.m.
h4zIQGxQ2qaxCd06TKri8T7oLRdhd50tLq8r5FucSTIVISB0eJ43uiDQ4bZaMDJb
