mrhappy
mrhappy HalfDork
10/14/16 6:45 a.m.
What part store has the best house brand pads?
It's time to do the brakes on my 96 and I gotta save as much money as I can before the baby gets here.
Thanks Robert
belteshazzar
belteshazzar PowerDork
10/14/16 7:23 a.m.
Napa Altrom line of semi-metallic pads worked well for me. And cheap.
KyAllroad
KyAllroad UberDork
10/14/16 8:07 a.m.
I'd suspect any brake pads will be fine for a Miata for DD use. The nicer/grippier/more fade resistant pads are for autoX or track use.
It's a 20 year old car now however so you'd be well served to give the whole braking system a solid once over (flush the fluid, lube the slide pins, etc). You do know about the trick to winding in the rear calipers don't you?
iceracer
iceracer PowerDork
10/14/16 11:15 a.m.
I just put NAPA Proformer pads on my Fiesta an they suck.
they stop OK but the dusting is outrageous and the sometimes are noisy on light application.
Think I will go back to Ford OEM.
4SJCai8HNmEcsBTBAigHCMqJ97Kw9UDQudLPSHaOycvmClwJfdPxCABZQPPaJ0t9
