bravenrace
bravenrace MegaDork
5/14/15 10:32 a.m.
Anybody know of a good Camber setting for an NB with 17" tires? Looking for an aggressive street setup that won't wear the tires too much. For the record, I thoroughly understand alignments, I just don't know what settings would be best for this car. Thanks!
z31maniac
z31maniac UltimaDork
5/14/15 10:35 a.m.
What is your ride height? Spring rates? Desired use? Etc.
I liked my track setup on the street, but I ran low pinch weld heights in the 4.25"/4.75" F/R range.
-3 in front, -2.5 in back, 0 toe all around.
NOTE: This was on R-Comps and 800/500 AST coilovers.
bravenrace
bravenrace MegaDork
5/14/15 10:38 a.m.
In reply to z31maniac:
Its stock with the exception of the 17" tires, and its a DD.
Swank Force One
Swank Force One MegaDork
5/14/15 10:40 a.m.
https://www.flyinmiata.com/tech/alignment.php
bravenrace
bravenrace MegaDork
5/14/15 10:47 a.m.
In reply to Swank Force One:
Thanks Swank, that's what I needed.
Desmond
Desmond Reader
5/14/15 10:48 a.m.
Toe will wear tires much faster than camber ever will. You really want to pay attention to your toe settings. I run some pretty wicked camber on my E36 but run almost no toe, and my tires have held up just fine.
z31maniac
5/14/15 10:49 a.m.
bravenrace wrote: In reply to z31maniac: Its stock with the exception of the 17" tires, and its a DD.
Yeah, you won't get much camber at stock height, so just go for all of it.
Swank Force One
5/14/15 10:52 a.m.
That's the alignment i ran on the MSM. Really transformed the car.
For the SE, i'm shooting for more like the 949 dual duty alignment or the race alignment, but that's a completely different car.
5/14/15 11:06 a.m.
Two basic schools of thought.
If you're looking for something that's basically an extension of the original setup and have your spring/sway setup tuned to match, you can use these:
If you're running a big fat front sway and no rear sway, this is the sort of alignment that might work better for you:
http://949racing.com/miata-race-alignment-info.aspx
I use the former on my street car and the latter on my track car.
UuVrSMfsBmL0z1RzdBEBjmofbshTTjq6HvRJXVYTyxKuoZFTJJI5I0f7gAp8a9gI
