OldGray320i
OldGray320i Dork
1/4/20 4:23 p.m.
 It's right in the pulley area, but I see a couple small hoses, is there another one I'm not seeing that might be leaking, or am I hosed?
No squeaking from wp, but that's not a guarantee, either.
Stampie
Stampie UltimaDork
1/4/20 4:47 p.m.
Theres a hose with an O ring from the back of the water pump on the drivers side.
OldGray320i
OldGray320i Dork
1/4/20 4:53 p.m.
 Looking under the car, bottom of my lower radiator hose is wet, but I'll check that hose on the back of the water pump, runs vehicle on drivers side, yes?
Stampie
Stampie UltimaDork
1/4/20 5:00 p.m.
Yeah and comes out of the back of the pump. Can you see the weep hole with a mirror or something?
Rodan
Rodan Dork
1/4/20 5:32 p.m.
Mixing manifold on driver's side of engine:
The smaller pipe (with the heat wrap in the pic) runs to the heater core, and has an o-ring where it enters the mixing manifold.  If this is leaking, there's a good chance it will run down the lower radiator hose.
There's also a small hose (fitting can be seen forward by the belts) that runs to the throttle body and from there through the oil filter base and back to the rear of the engine.
OldGray320i
OldGray320i Dork
1/5/20 12:17 p.m.
All the hose locations are dry, but turns out that the overflow hose at the top of the radiator was loose (old hose).
But car had a couple drops on the ground right underneath the pulleys.  I'll be keeping an eye on it.
I need to do timing belt soon, get all the hoses when I change water pump as part of it.
Zm9jNvN5osayww0LUUbXQTFoNJSsqnpJV81EEh3FRyNzLXsRzHE0RiuznVWWqkSa
