Brett_Murphy (Agent of Chaos)
9/20/23 1:21 p.m.
The short version of this story is that the drain holes in the NC I picked up a while back were clogged.
Taking apart the interior, as mentioned in that thread, was too large a job at the time. So, what I did was to go underneath the car, open the drain flaps with a pick and run a trombone cleaner through it from the bottom. A bunch of gunk came out, and the holes drained well for a while. Unfortunately, this car resides outside and there are a bunch of mature trees around, so lots of debris is constantly falling on it.
The last storm I got, there was water on the floor boards again. I am unable to get my fat hands in there from top and run the trombone cleaner down very well- I keep missing the drain hole and pushing the cleaner through the interior OR it's so blocked up in there that the cleaner just skips over the top.
I plan on going under the car and cleaning it out again.
Moving forward, is there a trick to cleaning out the drain holes? Would removing the black plastic covers over the drain holes impede draining- in other words, do those covers guide the water towards the drain holes? If they weren't there, at least I'd be able to get a vacuum in there to get most of the stuff out and SEE the top of the drain hole to get the cleaner in there.
Should I just store the Miata with a tarp over the top? Get a car cover?
9/21/23 11:53 a.m.
Free Thursday bump for you. Anyone been through this before?
ScottyB
ScottyB HalfDork
9/21/23 12:46 p.m.
is there any way you could ram one of these HVAC Drain Gun rubber stoppers into the hole and blast it clean with C02?  i haven't been around an NC chassis to know if that might fit or mate up.
https://www.amazon.com/Homiom-Drain-cartridges-Included-Condensate/dp/B071JS76ZP
CrustyRedXpress
CrustyRedXpress Dork
9/21/23 12:47 p.m.
In reply to Brett_Murphy (Agent of Chaos) :
My  NC sat under a massive and glorious live oak here in FL. So depending on the season the drains would get clogged with pollen, leaves and acorns.
I just got on a quarterly schedule of cleaning the drains. I definitely remember getting better and hitting the drain hold with the cleaning rod, but don't remember removin the black plastic covers. I don't recall using a vaccum, but seem to remember pouring a couple quarts of water down the drains at the end to make sure they were clean.
tl;dr trying cleaning it quarterly and getting better at hitting the drain hole. The angle of the dangle matters, so to speak.
9/21/23 3:29 p.m.
In reply to CrustyRedXpress :
Thanks! I cleaned it a few months ago, so I am thinking it may be a monthly thing for where I live.
9/21/23 3:30 p.m.
In reply to ScottyB :
That might work if I could figure out where the dang hole is. I keep watching the videos and they make it look easy. I'm going to have my wife (who has much smaller hands than I do) try it out. I figure it can't hurt.
Noddaz
Noddaz PowerDork
9/25/23 9:25 p.m.
Maybe this?
$900 Tractor Supply.  Your Miata could be outside and inside at the same time.
yfwaDhjWqUn7P1vBbD4AemY8wFhgsYxpXn66txHNIJs8KvUnHKdAltxnuRvhm338
