chaparral
chaparral SuperDork
4/12/24 8:53 p.m.
The automatic Miata usually gets a dismissive one-liner review as part of the manual car's test, but I was surprised by the acceleration. It has a nice short first gear plus a torque converter. Hand-timing a 0-60 run with an 1800 rpm brake-torque launch showed 5 seconds flat. Have you seen any instrumented tests? Would it be a ringer for really tight autocross courses?
calteg
calteg SuperDork
4/13/24 8:59 a.m.
It's possible. The auto GR86 did shockingly well on track
CyberEric
CyberEric SuperDork
4/13/24 1:04 p.m.
I've never seen a magazine test an auto Miata. Not once in any generation.
Interesting information. I mean most if not all autos are quicker than manuals these days, so I suppose this would make sense.
rdcyclist
rdcyclist HalfDork
4/13/24 1:48 p.m.
What model year defines the ND2?
Mr_Asa
Mr_Asa MegaDork
4/13/24 1:52 p.m.
In reply to rdcyclist :
2019 through current, IIRC
4/13/24 3:59 p.m.
In reply to Mr_Asa :
I suspect we're going to see the 2024s referred to as ND3s as they have visible changes.
Something like 1/3 of NDs are automatics, and it's a higher proportion for the RFs - close to half if memory serves. I'm casually looking for a black RF GT and boy howdy are the stick shifts thin on the ground. I'd be okay buying an automatic one given my future plans except that I'm not 100% sure I wouldn't have to do some retroengineering to deal with the auto in a future swap.
Mr_Asa
Mr_Asa MegaDork
4/13/24 5:44 p.m.
In reply to Keith Tanner :
Interesting, what's the significant change in '24?
4/13/24 6:05 p.m.
New headlights, new interior stuff, new rear diff, new steering rack.
CrashDummy
CrashDummy Reader
4/15/24 7:05 a.m.
And a new shade of gray because the existing color palette was too exciting!
Driven5
Driven5 PowerDork
4/15/24 1:26 p.m.
Not that this is the end all be all of lap times by any means, but it may also be worth noting that the auto FRZ86 also retains a limited slip... The auto Miata does not.
Even if the auto actually has a 0-60 advantage over the manual, call me skeptical at it actually being that quick under more controlled conditions.
CyberEric
CyberEric SuperDork
4/15/24 2:30 p.m.
Good to know about the lack of LSD. That's a shame.
4/15/24 3:11 p.m.
Retrofittable. Mazda has never put LSDs in auto Miatas.
rdcyclist
rdcyclist HalfDork
4/15/24 3:15 p.m.
What are the differences over the years in Miata final drives? Ratios between MT and AT? Are the RX and Miata FD's interchangeable? Sorta like how the Datsun/Nissan FD's were in the 70's...
4/15/24 3:25 p.m.
"Over the years" as in since 1990? Ranged from 4.3 to 3.636 until 2016 and were easily interchangeable on the NA/NB. I think the same ring and pinion could be used on the NC as well, but it's a different housing.
The ND saw a significant change because the new manual transmission has a 1:1 6th gear - no overdrive. So it has a fairly tall 2.866 final drive. The auto uses a 3.586. I don't believe either of these is interchangable with the earlier cars, I'd have to dig into the specs and check the diameter.
rdcyclist
rdcyclist HalfDork
4/15/24 7:28 p.m.
Thanks Keith! That tall FD would be useful on a BEC Locost if it was adaptable to the earlier suspension system...
4/15/24 7:35 p.m.
If you can build a Locost, you can make the diff fit :)
khkVH1FQXFyb1KqTAqhcQczSHWgdWLVOYmusNtfRO3xS54z5CAprCeQGQAeVJMmd
