Sofa King
Sofa King Reader
6/24/10 10:11 a.m.
I have an 8.8 Independent Ford rear end in my V8 Miata. The other night a bolt came out of the passenger side mounting point causing the inner (all Ford) CV joint to pull apart. The axles are held into the diff by a snap ring. I know that you have to pry the stub axle out of the diff, but space for prying is limited. I am looking for suggestions on popping the remaining portion of the axle out. It looks like a bigger version of a ball joint tool would work, but I am not aware of such an animal.
Any Ideas?
DILYSI Dave
DILYSI Dave SuperDork
6/24/10 10:33 a.m.
Prying is best. If you can get the opposite side out, you can push the side in question out through the diff, unless it has a cross pin for the spider gears.
Sofa King
Sofa King Reader
6/24/10 11:08 a.m.
Thanks, Is it necessary to pry from 2 sides at the same time or can I use just one pry bar?
oldopelguy
oldopelguy Dork
6/24/10 4:07 p.m.
Might also be easier to pop the cover and pry in-between the spider gears so you can push the side out. Depends on if you have a limited slip or not, and if you can hold the other side (or don't care if it pops out too.)
Sofa King
Sofa King Reader
6/25/10 8:28 a.m.
Thanks for the suggestions. I couldn't get it to pry out, so I decided to put it back together on the car. There didn't seem to be any damage to the axle, so I replaced the grease and bought a new band clamp. It went together fairly easily. Hopefully it will hold up!
FcamQaIcEPz3MBhzbFnOhDEDvlxs36HagZiSjBImDqYqwQ921wn7OYJMfcNenUMM
