AxeHealey
AxeHealey SuperDork
7/7/24 3:20 p.m.
I need help. I bought this manifold and neither the company I bought it from nor the manufacturer can tell me what size fitting I need for the threaded hole intended for the brake booster. They said 3/8" was too small so it may be 1/2" BSP or NPTF. Nothing I can find at the usual spots fits. Of course the big box stores don't carry British pipe thread.
Here's the hole. The closest I can get with my thread gauges is metric 1.5.
To what would be the outside of the threads on a fitting at the top of the hole measures just about 7/8 of an inch or about 22.4 MM
I cannot tell whether or not it's tapered but the inside measures .8155 in or 20.72 MM
Does this seem to be M22 x 1.5?
Brotus7
Brotus7 Dork
7/7/24 4:31 p.m.
What's it go on? 15/16 Witworth if it's for something old and British?
JBinMD
JBinMD Reader
7/7/24 5:01 p.m.
If you could tell us who the manufacturer is and the year/make/model/engine it is going on then perhaps someone here is familiar with it and can help.
To determine if the hole is tapered see if you can find a socket that fits in the top of the hole but gets tight lower down.
TurnerX19
TurnerX19 UberDork
7/7/24 5:34 p.m.
Is this for the Healey or the BMW? If Healey it is BSP, and Pegasus is your best bet if it is not available from Moths. Original BMC was a banjo and banjo bolt even for a hose.
AxeHealey
AxeHealey SuperDork
7/7/24 6:50 p.m.
This goes on the BMW. Mounts dual DCOEs to a BMW M10 engine.
I bought it from Eurocarb/Dellorto and it the only branding anywhere is on the hardware bag which is Webcon.
Datsun240ZGuy
Datsun240ZGuy MegaDork
7/7/24 7:22 p.m.
Doesn't one of the BSP/NPT match? Like 1/2" thread is the same?
03Panther
03Panther PowerDork
7/7/24 7:42 p.m.
Sir Joseph had some odd engineering thoughts on threads but, but I don't think his standard included pipe threads. I would imagine that is a tapered pipe thread, of some flavor.
APEowner
APEowner UltraDork
7/7/24 8:04 p.m.
7/8 orb?
No Time
No Time UberDork
7/7/24 8:26 p.m.
Maybe 7/8-20 thread?
Male plug
02Pilot
02Pilot PowerDork
7/7/24 8:45 p.m.
This is the stock 2002 part, p/n 34331102538. The sealing ring is 07119963355, which is listed as "A22X27-AL"; there is no listing for the thread that I can find. No idea if it will fit, but that's what I'd try first.
Edit: Photo suggests thread is not tapered.
TurnerX19
TurnerX19 UberDork
7/7/24 8:55 p.m.
In reply to 03Panther :
BSP, British Standard Pipe, has nothing to do with the Prince of Darkness, and there are both straight and tapered BSP threads. The Germans never had a tapered pipe standard. In fact there is not yet any Metric taper pipe thread standard...Give em time....
7/7/24 10:07 p.m.
1.5mm is really close to 16tpi, not 20.
I wouldn't doubt that it's 22x1.5.
Hmm..
Summit lists a lot of AN adaptors... and when doing a general search for M22x1.5, also a GM transfer case plug.  https://www.summitracing.com/parts/ado-89059626#overview
AxeHealey
AxeHealey SuperDork
7/8/24 8:43 a.m.
In reply to 02Pilot :
Man, I never even considered that this would be made to accept a factory BMW fitting. That's definitely the bugger. I did order an M22 x 1.5 to AN6 fitting that will be here today and from the bit of information I have been able to dig up on that it seems to be M22... We'll see.
Thanks everyone.
03Panther
03Panther PowerDork
7/8/24 10:32 a.m.
In reply to TurnerX19 :
Joseph Lucas  was a few years younger than Sir Joseph Whitworth, and is only a prince in jokes. Not sure what the official designation of Sir means to the Britt's, but we have a couple ex-pats that would know.
No one mentioned random electrical gremlins in a "thread" about "threads" cheeky
Yes, there are many straight thread pipe fittings (usually sealed by an o-ring or washer) as well as tapered. Without having the part in hand, I thought I saw tapered. But NoTime and O2Pilot looked closer!
Witworth (officially started by a Joesph with a "Sir") thread standard is not related to BSP, or any other sealing type thread, was my only point. (It's definitely not 15/16 Withworth)
Sorry I confused some people, but in context of "threads", different "Joe's"
AxeHealey
AxeHealey SuperDork
7/9/24 8:59 a.m.
It is indeed M22 x 1.5
wvumtnbkr
wvumtnbkr UltimaDork
7/9/24 9:02 a.m.
Sir means they have been knighted.
RacingComputers
RacingComputers HalfDork
7/9/24 11:54 a.m.
A Knight of the Realm
03Panther
03Panther PowerDork
7/9/24 12:01 p.m.
In reply to wvumtnbkr :
That was my assumption, but was not positive. So, a Knighted Sir, would trump a Prince of Darkness (that wasn't really a prince?)
They were both genius level in the mid 1800, despite the common jokes!
iansane
iansane SuperDork
7/9/24 12:01 p.m.
In reply to AxeHealey :
You put an oring on that?
5dIh5UB6wtvK84MKixLtqoc5ARG1McZRPipaYsEoM8Ti59iUBzPEJvpOeQ0mMdww
