Junghole
Junghole SuperDork
10/22/21 10:26 p.m.
Specifically polycarbonate tail lights, and butyl. I'm taking some tail lights apart. Most people recommend 200°, but I see the melting point of most polycarbonate is 230°, and I know, for a fact, that a residential oven doesn't stay at "exactly" the set temp. It goes above and below to give a median temp. So if you set an oven to 200°, it can get dangerously close to melting my $500 tail lights. The inner lense is PAR or "Polyarylate"  and another lense is pmma which is Polymethyl methacrylate (melting point of 320°)
Meanwhile, butyl Stearate says it melts at 80°, and butyl acetate melts at 108°. But which butyl are we using in automotive tail lights?
I know someone here is one of those chemical scientist guys that can help out. This forum ALWAYS has the answer.
Professor_Brap (Forum Supporter) UltraDork
10/22/21 10:38 p.m.
I know my omni has butyl Stearate, and a heat gun gets them out. I know a head gun will separate the lens from housing also.
mad_machine (Forum Supporter)
mad_machine (Forum Supporter) MegaDork
10/22/21 10:40 p.m.
taking the lens off of the base?  I only ever put the oven on a low setting and let it sit.  Every 5 minutes I would pull and check.  The Glue generally melts before the poly
Junghole
Junghole SuperDork
10/22/21 11:20 p.m.
In reply to mad_machine (Forum Supporter) :
Right, but I've done this before on some junkyard NA taillights and they cracked apart at the lense when I went to pull apart. At $420 per light, I don't want to make that mistake again.
EIbQ38rJv5jYnDKi2ov9d8ailWuwkzeBskuqxxmheevh7KpemnkeIBwfLkKu0PXo
