In reply to pinchvalve (Forum Supporter) :
As noted, this philosophy definitely goes back to at least WWII. Germany was renown for making very impressive weapons systems... on paper. Even the V2 (unguided missiles they dropped on London many times), though absolutely world breaking in it's technology, the amount of effort that was put into it for the results (completely indefensible 2000lb bomb dropping out of the sky, but with only city size accuracy) is a bit hard to justify (now... if they were able to get a nuke...). Tanks are the best example. The Panther and Tiger have some impressive capabilities (guns, armor etc), but both were complex (expensive to build / maintain) and generally unreliable, thus far less practically useful. In one case, the mean time between failure for the transmission in combat use was similar to the range of the tank on a tank of gas!!!
If, for example, Germany had simply put all that effort into modernizing the Panzer IV, they would have ended up with many, many more tanks, without a huge downgrade in overall capability and crew training would have been much faster / easier. Much of this direction was the result of Hilter's meddling BTW (micro manager). He was a huge fan of the theoretical "wonder weapon".
The allies, certainly went the other way. I think the US (e.g. Sherman) more by necessity (they didn't have any other designs, immediately available), while the Russians clearly went with the numbers over precision route. They could pump out massive numbers of what is effectively the clunky T34 for the effort of building a Tiger, and you surround a Tiger with 5 T-34's, bad things will happen! This philosophy still survives a bit in Russia BTW, which I think has a bit more to do with creating things that appear to do what they are supposed to rather than actually doing it in practice (something that seemed to be common in Soviet Russia... essentially corruption).
Plane wise, Germany did a lot better. Some of their engineering innovations were just clearly a better designs. Their development of an altitude compensating supercharger is an example. Just set the boost level, and it adjusts based on altitude (over boosting in lower thick air is a big concern). Allied designs, even late in the war, required the pilot to manually select different blower levels, based on altitude (which I am sure was a bit of an issue in combat!).
Am I saying German engineering is still being influenced by Hitler, whether they admit it or not!?!
