gjz30075
gjz30075 HalfDork
11/17/15 3:16 p.m.
I just picked up a tube of the ultra gray permatex, specifically for thermostat gaskets and the directions say to wait 24 hours before filling with fluids. In fact, every Permatex tube on the rack at the parts store, no matter the application, says to wait 24 hours before filling with fluids. WHAT? Looking at my old tubes, they have no mention of a waiting period, other than a bit before tightening.
Is this a super conservative move on Permatex's part to stave off complaints about leaks, or has their formula changed?
Anyone use this new stuff and 'fill with fluids' right after assembly?
edizzle89
edizzle89 HalfDork
11/17/15 3:32 p.m.
gjz30075 wrote: Is this a super conservative move on Permatex's part to stave off complaints about leaks, or has their formula changed?
this would be my guess. yea maybe you could apply it then slap everything together and it doesnt leak a drop, but if it does Permatex can come back and say "we told you...". I usually just stick with a couple of hours for dry time to be safe.
dropstep
dropstep HalfDork
11/17/15 3:34 p.m.
Its there cover your ass policy. I think they changed the chemical compisition a bit because the ultra black and grey ive used recently took an hour to tack up decently enough to feel comfortable bolting it together.
Previously with ultra black i waited about ten minutes.
spitfirebill
spitfirebill PowerDork
11/17/15 3:37 p.m.
I can almost assure you they took the good stuff out and its probably not worth crap anymore.
Knurled
Knurled MegaDork
11/17/15 4:37 p.m.
Right Stuff still says "can put immediately into service".
WildScotsRacing
WildScotsRacing New Reader
11/17/15 4:48 p.m.
spitfirebill wrote: I can almost assure you they took the good stuff out and its probably not worth crap anymore.
Ehh, two weeks ago I just did a thermostat with a brand new tube of Ultra Black, both sides of the gasket. I waited 10 minutes to torque, an hour to fill, and another hour to crank and drive it for a full warm-up cycle. Same process I have used with the stuff for 30 years. It's holding just fine. I'm agreeing with the CYA theory.
Woody
Woody MegaDork
11/17/15 5:02 p.m.
Prematex customer service is pretty good. Ask them.
Javelin
Javelin MegaDork
11/17/15 5:05 p.m.
Easy way to find out, get the MSDS for the old and the new tubes.
dansxr2
dansxr2 Dork
11/17/15 5:35 p.m.
I had an issue on my MX-3 with the F2T Swapped in it. It was leaking on both sides of the Tstat housing to head , and the rear timing cover to head. I put it together with the grey Permatex, filled with fluids leaked profusely. Redid same job, and waited per directions, no issues at all.
The Hoff
The Hoff UltraDork
11/17/15 5:44 p.m.
I exclusively use Toyota FIPG sealant. Stuff is awesome.
Assemble within 15 minutes and "engine may be started in 1 to 2 hours"
sesto elemento
sesto elemento Dork
11/17/15 7:22 p.m.
The Hoff wrote: I exclusively use Toyota FIPG sealant. Stuff is awesome. Assemble within 15 minutes and "engine may be started in 1 to 2 hours"
This /\
vFCQYccoHV0cIQb5Taa3LMLopLYPVzQTwuDkHOoT1jF2qxE6zZ7O8Za6OIe8h1fX
