Jeff
Jeff SuperDork
9/11/16 11:47 a.m.
Apparently trying to find Nissan parts quickly in Canada is a bit of a E36 M3 show.
I need to find front pads for the AD22VF calipers that where swapped in the the 200SX from a NX2000. Apparently that's a common caliper so if you Nissan guys know of other applications were they were used I can feed that to the Parts Source; Napa; Crappy Tire monkeys and see if I can get parts.
Also trying to track down axles for the 2.0L manual with ABS. Again, the NX 2000 was suggested as a cross reference; are there any others?
Surprised to find parts this difficult to come by. Mazda parts are stupid easy.
Thanks!
Streetwiseguy
Streetwiseguy PowerDork
9/11/16 1:37 p.m.
You know that the calipers and axles came from an NX2000? Don't confuse the parts guy. Just ask for parts for the NX2000.
Those are a bit scarce up here, too. I wouldn't count on speedy service, since I have a B13 Sentra with NX2000 running gear, I know from where I speak..
Try to find someone who can buy from Worldpac.
Jeff
Jeff SuperDork
9/11/16 1:53 p.m.
Are the rears from the NX2000 and the 200sx the same? That would make it less confusing. What year NX do I tell them so they can find it?
Streetwiseguy
9/11/16 2:48 p.m.
I don't know, although I'd guess they are. Fronts, I'm pretty sure, are kinda unicorns. I don't think they are even the same as the B13 SER for some reason. I can cross stuff over at the shop tomorrow, if you don't find a better source by then.
YA
YA New Reader
9/11/16 3:00 p.m.
This may be of assistance it is for European models though but hopefully part numbers are the same. If you click on a part it gives model number and description and interchangeable parts For example
NGTD
NGTD UberDork
9/11/16 3:07 p.m.
Carquest can order from Worldpac
cleanone
cleanone New Reader
9/11/16 8:03 p.m.
A key thing to note is that all NX2000s were built in Japan. So you will see brake options for "cars made in Japan only" on places like RockAuto. Those are the parts you want. I do not know what the pad shape code is for the NX2000 calipers though. Those brakes are not legal on my SCCA ITA Sentra SE-R. Also, check out www.sr20-forum.com for all of the info you could ever want on these cars.
Oh and by the way, NX2000s were manufactured from 1991-1993 so those are the model years to look for. Make sure you get the correct rotors too, they are larger in diameter and thicker than the SE-R rotors.
captdownshift
captdownshift UberDork
9/11/16 8:43 p.m.
vXFBxiTx7eAXbJijQjZHznXmMJOcSduGyYH35waNyuooaJy4taPKrhtokWGqvB8b
