Dusterbd13
Dusterbd13 UltimaDork
6/6/17 11:46 a.m.
So i lost the water pump pulley.
I did the timing belt job about 5k ago. Replaced the water pump at the same time. Did not use locktite in the bolts. Should i have?
It also gnawed up the front civer pretty good, cutting the whole way through on tbe drivers side of the pulley.
Other than just locktite the replacement bolts, what should I be looking for? Seems to run a little odd now. Did not overheat per the gauge. Stayed right where it always reads.
Im thinking that i need to tear the whole qay in and check the belt for damage. Hope not....
What all should i put a close eye on? Is this a common problem, or did i somehow just not get the bolts tight enough 5k ago?
Blaise
Blaise Reader
6/6/17 11:48 a.m.
Honestly I'd replace the water pump too. That bearing can't be happy.
I've never locktited those bolts and never had them back out either.
LuxInterior
LuxInterior HalfDork
6/6/17 12:05 p.m.
"front civer"? Wazzat?
I didn't Loctite mine when I put it together. No issues. Did you make sure you had everything lined up correctly when you put the belt on?
Dusterbd13
6/6/17 12:08 p.m.
From what i remember, everything was per spec.
I believe that i probably will change the water pump due to bearing. And the threads dont seem too healthy anymore either.
And damned typo. Front COVER.
yqqy3J5KhAWnDUK6W0O6CjQPdgUCBKybBPWqwk4jZ3URdyjmRsWOQ3tCGuGkoYEJ
