HappyAndy
HappyAndy HalfDork
11/28/11 3:28 p.m.
See, I avoided "learn me".
I am planning to relocate my SAAB c900 turbos battery from the OEM location in the front RH corner of the engine compartment (right next to the turbo & downpipe), to the trunk. I've already obtained a gel cell battery and plenty of copper cable, what else do I need to make a clean installation? My plan is to make a shallow recess in the trunk floor and weld in some brackets to hold it in place with a bar and J hooks, the finished product should be concealed under the hatch of the spare tire compartment. I want to use this car as a general purpose motorsports beater (Auto-X Rally-X HPDE and hopefully even a $20XX challenge). I know different sanctioning organizations have varied rules about this sort of thing, so what I'd like to know is if this plan is likely to fly or fail if checked out by a tech inspector? I will be using a gel cell battery, so hyI shouldn't need a vent to atmosphere, and it will be
under the spare tire hatch cover so it will be enclosed and separated from the cabin of the car.
iceracer
iceracer SuperDork
11/28/11 4:59 p.m.
What size copper cable.?
irish44j
irish44j Dork
11/28/11 7:02 p.m.
here's a good write-up of a good system. Very similar to the way I did mine in my wrx (except I used a blade-fuse box in the back instead of a circuit breaker)
http://wgbuckley.com/projects/battery.html
Even with the gel cell, it's best to seal it in a box, in my opinion, and vent it anyhow. IIRC gel cells CAN vent, they just don't under normal circumastances (coudl be wrong about that). I'm pretty sure most tech inspectors for track events are going to be looking for that (not autocross), though again I could be wrong.
As the previous post inferred...cable size matters. In the WRX I used 4-gauge (with heavy marine sheathing), but I definitely get some voltage drop along the long run of wire with that gauge, and the car cranks much slower. I would go no smaller than 2-gauge so you're getting full voltage to the starter. Even the stock e30 trunk battery cable is 1-gauge I think. I got the 4ga for free (parents own a marina), so I used it. If I was buying for the application I'd go larger.
Also when you run the wire, make sure to secure it well and anyplace it goes near anything with an edge, wrap it with some plastic/rubber tubing so it doesn't chafe through to the copper.
TRoglodyte
TRoglodyte HalfDork
11/28/11 7:08 p.m.
iceracer wrote: What size copper cable.?
QFT amp draw on a cold start could be an issue. Welding leads or romex?
donalson
donalson SuperDork
11/28/11 7:14 p.m.
I've read of a number of people pulling the battery cables from BMW's at the JY to get cable for cheap... thats my plans here soon for the s10
corytate
corytate HalfDork
11/28/11 7:31 p.m.
very well shielded heavy gauge copper cable for sure.
maybe a box for it even
run the cables so they aren't going to be pinched by anything (of course)
idk what else
xFactor
xFactor New Reader
11/29/11 6:04 a.m.
I like to double up a pair of 200 amp ANL style fuses (in parallel) in case things go really bad.
later, matt
Ranger50
Ranger50 Dork
11/29/11 7:01 a.m.
When I did mine in my Ranger, I used 00 welding cable with marine grade hammer crimp lugs on the ends. I just copied the OEM battery cable attachment points and it fired right up. Don't forget about a kill switch too. I know not everyone says to use it, but it makes killing a hot vehicle easier.
HappyAndy
HappyAndy HalfDork
11/29/11 7:04 a.m.
2/0 welding cable, and I have I have the equipment to make properly crimped cable ends.
iceracer
iceracer SuperDork
11/29/11 9:12 a.m.
I asked because some have been done with sound system cables. With poor results.
steronz
steronz New Reader
11/29/11 10:10 a.m.
NHRA requires an external kill switch (battery and alternator) if the battery is not in the stock location. As far as I know, they have they most strict rules about battery relocation. I don't know if the $20xx challenge uses NHRA rules for the drag strip portion, but I would suspect that nobody would care. That's all I have to add to this discussion.
ETA: I also had a drag strip tech bitch about my gel cell battery not being in a vented box once. I tried to explain that it was a gel cell and didn't vent anything, but he didn't seem to care. The rulebook doesn't make a distinction.
porschenut
porschenut New Reader
11/29/11 11:51 a.m.
I was concerned about chafing so I sprayed the cable with silicone spray and slip it into a braided garden hose for additional protection.
MadScientistMatt
MadScientistMatt SuperDork
11/29/11 12:00 p.m.
donalson wrote: I've read of a number of people pulling the battery cables from BMW's at the JY to get cable for cheap... thats my plans here soon for the s10
Yep. Most BMWs had trunk mounted batteries and they've got battery cables that are great for battery relocation. Using one on my Dodge Dart.
Sky_Render
Sky_Render Reader
11/29/11 12:04 p.m.
Make sure the ground connections are secure and clean. (Sand the paint off before bolting them.) You may wish to run a separate cable for ground.
corytate
corytate HalfDork
11/29/11 12:09 p.m.
saturn ion's also had trunk mounted batteries. idk if only limited number of years or all production, but I saw one yesterday here (we used to be a saturn dealer so we still get a lot of saturns in)
mad_machine
mad_machine SuperDork
11/29/11 1:48 p.m.
I have thought about doing this to my c900 turbo as well. I think in the end I am just going to go with the same small gelcell I put in my BMW. hopefully 625CCAs will be enough to crank over the lowcompression engine... seems to work well on the highcompression BMW engine
Karl La Follette
Karl La Follette Dork
11/29/11 4:10 p.m.
Boats have really long battery cables in them
irish44j
irish44j Dork
11/29/11 5:28 p.m.
Karl La Follette wrote: Boats have really long battery cables in them
Most marine battery cables are 4 gauge. Ask me how I know ;)
HappyAndy
HappyAndy HalfDork
11/29/11 6:57 p.m.
xFactor wrote: I like to double up a pair of 200 amp ANL style fuses (in parallel) in case things go really bad. later, matt
How did you come to this arrangement? Why parallel 200s and not a single of a higher amperage, and how does one determan the best fuse amperage for a given application?
I definitely want a fuse mounted near the battery , my seat of the pants guess would be a 175 or 200 amp single, but if there is a formula I'd like to know it.
HappyAndy
HappyAndy HalfDork
11/29/11 7:03 p.m.
mad_machine wrote: I have thought about doing this to my c900 turbo as well. I think in the end I am just going to go with the same small gelcell I put in my BMW. hopefully 625CCAs will be enough to crank over the lowcompression engine... seems to work well on the highcompression BMW engine
Have you inspected your frame around the RH lower control arm mounts for battery acid induced rust yet?
HappyAndy
HappyAndy HalfDork
11/29/11 7:06 p.m.
porschenut wrote: I was concerned about chafing so I sprayed the cable with silicone spray and slip it into a braided garden hose for additional protection.
I was planning to do the same thing with scraps of hydraulic hose as conduits in areas where the cables could chafe.
irish44j
irish44j Dork
11/29/11 7:14 p.m.
How did you come to this arrangement? Why parallel 200s and not a single of a higher amperage, and how does one determan the best fuse amperage for a given application? I definitely want a fuse mounted near the battery , my seat of the pants guess would be a 175 or 200 amp single, but if there is a formula I'd like to know it.
I'm using an ANL 200 in a box just outside my battery box. If you have a long-term short, that will blow. But it's a slow-blow fuse, so even during long cranking at high amps, it's still fine.
HappyAndy
HappyAndy HalfDork
11/29/11 7:17 p.m.
As far as an external kill switch goes, if the car gets to the point that its spending more time at the track than the street I'll add one in then, this car also does duty as a dog and MTB hauler too.
mad_machine
11/29/11 7:59 p.m.
I have surface rust.. caught the car before it got expensive to repair. Once I get the engine out monday, I can start sanding and painting the engine bay
xFactor
xFactor New Reader
11/29/11 10:25 p.m.
Just about every relocation I do is v8 stuff in the trunk for customers, and while I want them to be safe, I also don't need it to fail out in South Krackolaka. The biggest single ANL fuse easily found is 300amps and that would probably be fine in 95% of the time.
I tested/sacrificed a 200amp ANL on a pat musi 555 crate engine and it cranked over for a while as we set the timing, maybe 15 times or so before it failed. I double up the 200's for a total of 400amps for a lot of headroom, in case of low voltage situations, but low enough so if they get in a wreck it will pop.
later, matt
LZhTcVS23pAQlMbbtKbiCwQYzZy0JAVLYdV5iuseyw47tNLmV3up79kP6IPtPOL3
