bmw88rider
bmw88rider UberDork
1/13/25 10:59 a.m.
Angeles Crest is a lot of fun but yeah not the time to go with the fires and snow. Did it twice when I bought cars out there.
Andy Hollis
Andy Hollis
1/13/25 7:19 p.m.
Houston, we have a problem.  Two, actually.
Saw some grease on the inside of the wheel and investigated today.  Appears to be a small cut in the axle boot near the band clamp.  Probably happened when replacing the hubs as it's challenging to get a socket in there with the axle in the way.
Sometimes "an ounce of prevention" becomes "No good deed goes unpunished"
And what was once a minor occasional weep in one of the front calipers turned into a full fledged drip.  Enough that the master was low.  Happened after it was 24 degrees out the other night.
I'm willing to run the axle to its death at a track day but not brakes.
Will see if the fluid issue is still there tomorrow.  That could be a deal breaker.
brandonsmash
brandonsmash HalfDork
1/13/25 7:45 p.m.
Oof. Well, if it can hold on a bit you're welcome to my tools and space if you're headed back through Phoenix.
Andy Hollis
Andy Hollis
1/17/25 6:27 p.m.
Brake leak persisted all week so car is back on the trailer and our weekend at Chuckwalla cancelled.  Next year.
Contemplated a heroic field repair with expedited parts delivery, but not worth it.
Edit: But I did just fix that trailer shield rip with zip ties, just after this pic was taken.  :)
Andy Hollis
Andy Hollis
1/28/25 12:30 p.m.
Bumping this back up for a final installment.  TL;DR repairs have been made and the car is back in service.
When I got home I was just about to hit the Order button at Mazda Motorsports on a shopping cart full of fresh parts when I came across a nearby FB sale of never-tracked Brembo calipers and serviceable rear axles at a great price. A quick trip to Dallas and they were mine.
Andy Hollis
Andy Hollis
1/28/25 12:31 p.m.
Calipers went on super easy w/o much fluid loss.  So fresh.
Andy Hollis
Andy Hollis
1/28/25 12:39 p.m.
Axle was a challenge.  Specifically, removal of the old one.  The retention clip seemed hell-bent on doing its job forever.  Tried all my usual prying techniques to no avail.
Factory method uses a slide hammer with an adjustable adapter.  I have the former but the latter is $200.  Sorry, no sale.
Instead, I found a fixed width adapter on Amazon and opened up the gap with an angle grinder to fit.  Once I got it all lined up right, a couple good whacks and the retention clip was defeated.
Andy Hollis
Andy Hollis
1/28/25 12:42 p.m.
Offending slit in boot most likely from socket impact during hub R&R.  An once of prevention sometimes requires a couple pounds of cure.
All cleaned up.
M5FVh2LaRNXNs1eO76ry8YmtwmkMjyNYkBuNIqRe8Gc687zsnCin6IVmX6jYtYD4
