stan
stan SuperDork
8/26/09 10:06 a.m.
My CRX HF alloys were painted black. Is there any easy, safe way to remove it?
I hate this most of the time, but see it done a lot.
Stan
Keith
Keith SuperDork
8/26/09 10:15 a.m.
Bead blasting or Jasco paint stripper from Home Depot.
Tom Heath
Tom Heath Marketing / Club Coordinator
8/26/09 10:15 a.m.
If it's just spray paint, try Easy-Off oven cleaner.
You'll still have to repaint them silver to make them look nice, but so if you've got access to more aggressive paint removal equipment (media blaster?) go for it.
Toyman01
Toyman01 HalfDork
8/26/09 3:15 p.m.
I stripped my gold RX-7 wheels with Strip Ease. It worked pretty well. I still had to do some blasting to remove some corrosion, but it removed the paint without any problems. I won;t leave you a nice finish on the aluminum though. You will need to repaint.
Keith
Keith SuperDork
8/26/09 4:15 p.m.
The Jasco leaves a decent finish on the aluminum. Did anyone know the faces of Miata wheel spokes were polished under the factory paint?
stan
stan SuperDork
8/26/09 8:47 p.m.
Looks like I'll try the Jasco and will keep in mind the other tips (thanks). I wonder, if I decide they need it, if a mild polish would bring back a bit of the luster after using the Jasco.
Stan
toddgreene
toddgreene New Reader
8/26/09 8:56 p.m.
Acetone will slowly dissolve the paint and not harm the aluminum at all. It will however strip off any clearcoat that be on the wheel. Of course, in August it evaporates almost instantly.
Todd
Woody
Woody SuperDork
8/26/09 8:57 p.m.
Keith wrote: Did anyone know the faces of Miata wheel spokes were polished under the factory paint?
Just the Daisies or are the 94-97 14's polished, too?
Keith
Keith SuperDork
8/26/09 9:57 p.m.
Never stripped the 94-97s, but they don't have a flat ridge down the face so I don't think so.
joey48442
joey48442 SuperDork
8/26/09 10:25 p.m.
Daisys would look neat with the polished left bare and the rest painted something dark. I don't think I could tape well enough to make them look good, though.
Joey
Keith
Keith SuperDork
8/26/09 11:41 p.m.
They do Here's that same wheel, later.
Trans_Maro
Trans_Maro HalfDork
8/26/09 11:47 p.m.
toddgreene wrote: Acetone will slowly dissolve the paint and not harm the aluminum at all. It will however strip off any clearcoat that be on the wheel. Of course, in August it evaporates almost instantly. Todd
Umm, that's different from what I've been told.
One of the local gas engine shops that my repair shop contracted to built competition chansaws (loggers sports).
The ran a lot of acteone in the fuel mix for more octane, apparently if you didn't drain the tank, you'd have a hole in it by morning.
Shawn
Duke SuperDork
8/27/09 8:05 a.m.
It evaporates when exposed to air, which it wouldn't be in the tank.
ratghia
ratghia Reader
8/27/09 2:40 p.m.
I would try graffiti remover and supper fine steel wool. Just lets the graffiti remover sit for a few minutes and then scrub with the steel wool afterwards washing with hot water. Graffiti remover is designed to only attack one layer at a time.
Keith
Keith SuperDork
8/27/09 2:54 p.m.
Wow, is that graffiti remover pulling off a crap brown paint job to reveal baby blue goodness? That's impressive.
ratghia
ratghia Reader
8/27/09 4:19 p.m.
Just a little rubbing would pull the 70's gold re-spray off and leave the original blue undamaged. The car was the 1964 Karmann Ghia I took to the challenge in 2008.
Ttx92eVjEk7iX96beIwMGczx8sZ6Far0hxuJMlorDOUvMVB78Ja4tZY2fUTsmTmO
