speedblind
speedblind Reader
12/2/11 5:24 a.m.
So I lucked into a set of four rear DSIIs to use as track wheels. The wheels themselves are fine, but were subjected to a DIY paint that was left uncleared and unwashed...basically, the paint is now flaking off, and what's left has so much brake dust embedded in the surface that it all has to go.
I remember awhile back seeing a link to Keith's site where he used paint stripper to remove paint from a Miata wheel. Is that the route I should go, or should I drop them off at a shop to have them sandblasted?
Wheels in question look like this when hotlinked. Basically, sanding four of these by hand would make me sad.:
dean1484
dean1484 SuperDork
12/2/11 5:59 a.m.
Your thread title has me thinking of somthing compleetly different.
SyntheticBlinkerFluid
SyntheticBlinkerFluid Dork
12/2/11 5:59 a.m.
How many singles is it going to take to pay those strippers?
JoeyM
JoeyM SuperDork
12/2/11 6:17 a.m.
best title ever
Dusterbd13
Dusterbd13 Reader
12/2/11 6:18 a.m.
i used a spray can of aircraft stripper on my trucks wheels. got most of the paint, but not the powdercoat under the 4 layers of paint, finished the stripping with an air powered zizz wheel and a medium sos pad. prep, paint.
michael
1988RedT2
1988RedT2 SuperDork
12/2/11 6:32 a.m.
This thread has a lot of potential.
Toyman01
Toyman01 SuperDork
12/2/11 6:42 a.m.
I can't wait to see GPS's response to this one.
mad_machine
mad_machine SuperDork
12/2/11 7:45 a.m.
Dusterbd13 wrote: i used a spray can of aircraft stripper on my trucks wheels. got most of the paint, but not the powdercoat under the 4 layers of paint, finished the stripping with an air powered zizz wheel and a medium sos pad. prep, paint. michael
that would do it. If you get down to the original paint (which I think was powedered on) you can get it smooth and repaint. (or leave as is, depending on they look)
You know that DS and DSII rims are heavy right?
The0retical
The0retical New Reader
12/2/11 7:47 a.m.
MEK (methyl-ethyl-ketone) will remove virtually anything and does not damage metal. It stinks to high heaven, causes liver cancer (eats regular thin surgical gloves so get thick ones and double up), and is flammable but I've never used anything that will remove even epoxy based paint better, well besides purple skydrol.
Should be able to pick up a bucket of it at Home Depot for a couple bucks.
jrw1621
jrw1621 SuperDork
12/2/11 7:57 a.m.
If black is in your future, I am intrigued by this idea of painting rims with Plasti-Dip.
http://www.dipyourcar.com/shop/page/4?shop_param=
pigeon
pigeon Dork
12/2/11 9:07 a.m.
jrw1621 wrote: If black is in your future, I am intrigued by this idea of painting rims with Plasti-Dip. http://www.dipyourcar.com/shop/page/4?shop_param=
Now I know what I'm going to do with my ugly track wheels this winter.
ReverendDexter
ReverendDexter SuperDork
12/2/11 9:46 a.m.
You lied.
There is supposed to be an instructional video in here.
I expect this to be rectified.
carguy123
carguy123 SuperDork
12/2/11 9:50 a.m.
I wonder how long the dipped finish lasts?
And I am disappointed about the strippers. I envisioned you putting paint on the strippers and they used their bodies to transfer the paint to the wheels.
jrw1621
jrw1621 SuperDork
12/2/11 9:52 a.m.
I read somewhere in reviewing the dipped wheels opinions of lasting 5 month with winter conditions and 1 years without winter (snow/salt.)
Raze
Raze SuperDork
12/2/11 9:55 a.m.
why not just paint the wheels with duplicolor wheel paint, or engine block enamel, had both on different sets of wheels on our track rat, both tough as hell and work and look great, no marring or burn-through from hot brake dust, easy to clean, just my .02...
carguy123
carguy123 SuperDork
12/2/11 10:14 a.m.
Along these same lines I scored a set of wheels for cheap that had one wheel sandblasted into a dull finish but the other 3 were factory clear coat. Do I need to blast the other 3 before refinishing?
I've seen how to remove the clear coat on this thread without blasting.
rotard
rotard Reader
12/2/11 10:19 a.m.
Do you tip them with $1's or $2's while they're painting?
pinchvalve
pinchvalve SuperDork
12/2/11 10:42 a.m.
Stripper, Rim, Pole, Wheel...seems like there's a dirty joke in there somewhere.
mr2peak
mr2peak Reader
12/2/11 11:17 a.m.
I think this is a horrible idea, just paint them properly.
bigbens6
bigbens6 Reader
12/2/11 12:07 p.m.
My first thought is that you need to plan on a group shower for cleaning up, don't wanna leave that overspray on bare skin too long....
turboswede
turboswede SuperDork
12/2/11 1:02 p.m.
...just don't get it on your hootus!
oldtin
oldtin Dork
12/2/11 1:39 p.m.
My first thought was of strippers painting wheels - but followed by strippers getting painted, then had a random thought come and go about getting paint off of wheels. Aluminum sands easy.
speedblind
speedblind Reader
12/2/11 1:52 p.m.
I see my experiment to increase traffic worked. Sorry for the letdown - won't be the last time I'm afraid.
As for weight, yep they're heavy. Sad to say, but I suspect that my track times on the lightest wheels vs. these would be fairly similar, and these were ~$80/wheel.
As for duplicolor, that's what's on them now. From the looks of it, whoever painted them did zero prep, and thus there is not much adhesion. They were also never washed and are a matte/textured finish, so they're unbelievably grimy. I'm looking to press re-set, prep carefully and re-shoot with a basic dark grey paint.
warpedredneck
warpedredneck New Reader
12/2/11 4:43 p.m.
dean1484 wrote: Your thread title has me thinking of somthing compleetly different.
Me too, I'm pretty sure they prefer to be called exotic dancers!
mndsm
mndsm SuperDork
12/2/11 4:45 p.m.
Toyman01 wrote: I can't wait to see GPS's response to this one.
You probably ruined it, and he'll straightface it, if he posts at all.
sENwN8xzVrtcawXBLudVxCKD6hZIITgLva6AjfVgam7UfWbmsUgkvvnvAsnNPkvj
