aussiesmg
aussiesmg SuperDork
12/24/11 11:43 a.m.
Wow, this is so awesome, even if it is a reproduction
http://cgi.ebay.com/ebaymotors/Pat-Clancey-six-wheel-Indy-car-complete-offy-Built-AJ-Watson-/110794614866?pt=Race_Cars_Not_Street_Legal_&hash=item19cbdfa852#ht_500wt_1182
jrw1621
jrw1621 SuperDork
12/24/11 11:56 a.m.
Is that a hot pipe next to your right side shoulder?
Kram
Kram New Reader
12/24/11 11:58 a.m.
jrw1621 wrote: Is that a hot pipe next to your right side shoulder?
I'd be more worried about the spinning driveshaft under my privates!
Curmudgeon
Curmudgeon SuperDork
12/24/11 12:00 p.m.
Not to mention a driveshaft just below your goolies? Better not disable the speed limiter.
oldopelguy
oldopelguy Dork
12/24/11 12:04 p.m.
The driveshaft is enclosed on that driveline, FWIW.
jrw1621
jrw1621 SuperDork
12/24/11 2:43 p.m.
What do you think the plunger looking thing does? (left side hand)
Is that the shifter, the hollow metal tube at about 7 o'clock of the steering wheel?
stuart in mn
stuart in mn SuperDork
12/24/11 3:57 p.m.
The plunger is for pressurizing the fuel tank, to push fuel to the engine.
Curmudgeon
12/24/11 4:14 p.m.
oldopelguy wrote: The driveshaft is enclosed on that driveline, FWIW.
Ever seen the pic of the Jensen's floor after the driveshaft let go? That's still a cool car, even if it is a repro.
a401cj
a401cj Reader
12/24/11 5:07 p.m.
hot pipe? spinning shaft right beneath your nads? You guys are too wussified. Remember, you'll be doing close to 190 down the back-straight in a tee-shirt, open face helmet, and maybe not even wearing a seatbelt. Seeeesh
fast_eddie_72
fast_eddie_72 SuperDork
12/24/11 11:22 p.m.
Man, that is awesome
SlickDizzy
SlickDizzy SuperDork
12/25/11 12:18 a.m.
a401cj wrote: hot pipe? spinning shaft right beneath your nads? You guys are too wussified. Remember, you'll be doing close to 190 down the back-straight in a tee-shirt, open face helmet, and maybe not even wearing a seatbelt. Seeeesh
Quoted for truth!
44Dwarf
44Dwarf Dork
12/25/11 7:25 a.m.
don't forget one hand on the steering wheel the other pumping up the fuel tank. Whos got the key i want to drive it!
Curmudgeon
12/25/11 8:22 a.m.
There was a Mercedes Simplex? race car way back when with open chain drive on both sides. It took two people, a driver and a mechanic, the driver, well, drove. He ran the throttle, steering and brakes. The mechanic had to work a manual engine oil pump (!), chain oilers, manual fuel pump and also had to adjust the brakes. He was definitely a busy guy. Seems those cars had drum brakes which could be cooled by an onboard water sprinkle.
jrw1621
jrw1621 SuperDork
12/25/11 8:42 a.m.
http://www.youtube.com/watch?v=eQh31N5DAfM
Here is a little commentary about the car from its current owner.
Picture with a driver.
Note the t-shirt, open helmet and lack of seat belt.
If link not working, find picture in here...
http://www.trackforum.com/forums/showthread.php?137277-OT-The-Life-And-Death-Of-The-Six-Wheeled-Race-Car-Delta-Wing-haters-need-not-apply
Dr. Hess
Dr. Hess SuperDork
12/25/11 8:53 a.m.
A guy in my car club has a car almost identical to that, but it is not a reproduction. The fuel "pump" is on the right on his, and it's powered by a Ford tractor motor with a race head. It only turns left. Seriously. You can go straight or left. He hit his mailbox the first time he drove it because of that. Push start only.
3la1fTVy0PDzi02yTq3IKWDAeHenaKP2HOIZ7TouaUPcGT5sJcgpBPkYoeWtNSJo
