Bobzilla
Bobzilla UltimaDork
4/15/16 10:02 a.m.
http://www.motusmotorcycles.com/american-v4
Quick specs: 180hp/126ftlbs, 8500rpm, 150lb engine wet V4 16" long, 20" wide and 26" tall.
mad_machine
mad_machine MegaDork
4/15/16 10:32 a.m.
that's pretty cool.. basically a cut down SBC?
jstein77
jstein77 UltraDork
4/15/16 10:33 a.m.
Pushrods in a Lotus?
RossD
RossD UltimaDork
4/15/16 10:35 a.m.
In reply to mad_machine:
It said it's only 100cid so it's not just half of a V8. Whether or not it's scaled, I don't know.
bluej
bluej UltraDork
4/15/16 10:41 a.m.
I'm intrigued..
WilD
WilD HalfDork
4/15/16 10:50 a.m.
When I originally read about these (a couple years back) I think the idea was that it was based on the SBC and even shared some components. I'm not sure how that concept has evolved into the production engine...
Bobzilla
Bobzilla UltimaDork
4/15/16 11:11 a.m.
1600 CC'S, so doubled would be 3200-ish. that's getting closer to the 4.8L. I guess if you destroked it and made the bores a little smaller you could get there.
EDIT: So the bore/stroke on the MV4 is 3.46/2.67 and the 4.8 is 3.77/3.27 so it could be the same basic block. Interesting..... MV4 rods in an LR4?
Knurled
Knurled MegaDork
4/15/16 11:58 a.m.
RossD wrote: In reply to mad_machine: It said it's only 100cid so it's not just half of a V8. Whether or not it's scaled, I don't know.
Hot Rod or Car Craft did an article about this engine about five-ten years ago. It's kind of LS inspired but everything is scaled for motorcycle use. IIRC it actually does use an LS cam sprocket.
Driven5
Driven5 Dork
4/15/16 12:17 p.m.
Building it to actual LS dimensions without utilizing the extra capacity they offer might be fine in a car, but would be little more than wasting vital packaging space in a motorcycle. Which is why it wouldn't make sense for it share any critical dimensions with the LS engines that it was inspired by. It's certainly a cool engine though, and I'm glad it exists. However, if my project finances could actually afford one of those engines, I'd probably try to DIY build a true LS derived V4 for myself instead.
KyAllroad
KyAllroad UltraDork
4/15/16 12:23 p.m.
That would be cool in a Miata! I like the sound (former Honda Magna owner and fanboi
noddaz
noddaz Dork
4/15/16 2:26 p.m.
Maybe in a Super 7 type car...
Bobzilla
Bobzilla UltimaDork
4/15/16 2:37 p.m.
noddaz wrote: Maybe in a Super 7 type car...
That is exactly what I was thinking.
wspohn
wspohn HalfDork
4/16/16 2:33 p.m.
Too many other options - reprogram a Cruze engine for the same or better output
Driven5
Driven5 Dork
4/16/16 3:19 p.m.
Power is just a number...The Cruze engine would never be able to look or sound this interesting:
180 HORSEPOWER V4 Powered RZR XP 1650
On the track - RCR Monoposto powered by Motus MV4 takes on COTA
Trackmouse
Trackmouse Dork
4/16/16 7:32 p.m.
K, I thought the only good lotus engine was made by Toyota?
FatWFedSVAGf1oGCNrdCMb2pHgyeGuwv9JbuekgrWY2VsFezGs98eeebMsuhrD31
