DILYSI Dave
DILYSI Dave SuperDork
3/21/09 11:55 p.m.
Since I'm now boosted, and that can play hell with the stock PCV system, I'm considering scrapping the stock stuff entirely and putting a pitot tube into the exhaust stream, and hooking the valvecover vent to it. Anyone played with this?
Summit has a few kits for this. http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-120108&N=700+4294851516+115&autoview=sku
From reading online, some people love them, some hate them.
Trans_Maro
Trans_Maro Reader
3/22/09 1:04 a.m.
You need an exhaust with NO backpressure for them to work effectively.
Shawn
blaze86vic
blaze86vic Reader
3/22/09 1:38 a.m.
Yeah, if you have a restrictive exhaust it won't work. I too am interested in a solution to this dilemma. I was thinking that an electric vacuum pump may be the solution, but it's low on my priority list of things to design up right now so I haven't done much beyond concepts.
stan_d
stan_d Dork
3/22/09 7:49 a.m.
my plan is to make a oil air seperator then hook it to intake pipe in front of turbo
warpedredneck
warpedredneck New Reader
3/22/09 7:56 a.m.
used that system in the stock car(late model circle track) worked well, had to change the valve frequently, 3 times a season. it would really start to smoke!
ncjay
ncjay New Reader
3/22/09 7:58 a.m.
Many drag racers use this system so it must work well enough, but they only need it for a few seconds at a time and they sure don't have any back pressure. A vacuum pump is a great idea and you'd probably see more benefit from that over running a tube into the exhaust.
DILYSI Dave
3/22/09 8:04 a.m.
Exhaust isn't restrictive - 3" straight pipe into a turn down. That's it.
I could do the vacuum pump, or separator, or other stuff, but it's more weight and more complexity. If it will work, I REALLY like the simplicity of this.
Warped - when you say you had to change the valve - I assume you're talking about the check valve? I was wondering if it's even necessary to run it.
P71
P71 Dork
3/22/09 8:37 a.m.
I was always happy with running a vented catch can. Summit sells some plastic NHRA-legal ones for cheap (~$20?). I ran a hose from the OEM breather port on the valve cover to it and from the OEM PCV port on the cranckcase to it plus capped off the oil-sucking port on the intake. Worked like a dream in a turbo car, cheap, and you can keep track of blow-by.
The pitot idea sounds brutally simple and effective though...
fifty
fifty New Reader
3/22/09 8:53 a.m.
P71 wrote: I was always happy with running a vented catch can. Summit sells some plastic NHRA-legal ones for cheap (~$20?). I ran a hose from the OEM breather port on the valve cover to it and from the OEM PCV port on the cranckcase to it plus capped off the oil-sucking port on the intake. Worked like a dream in a turbo car, cheap, and you can keep track of blow-by.
Same here, I stuffed it with steel wool to encourage the oil vapor to condense in the catch can. Had a drain hole with a stopcock tapped on the bottom of the catch can, would bleed off the oil periodically.
It was kinda stinky when it was venting, but it was a "race only" vehicle.
ww
ww Dork
3/22/09 1:42 p.m.
I'll be interested to see what you come up with.
Xz0VHdFwdfxF2EurHHbyEKF7Doe3qygOspaErDeS0OBVZZcRxZFPoSFgt1F04ZMx
