What do we think is wrong with this thing? Ignition system? Carbon buildup on something important? Something way worse? Rust may be a deciding factor, although I'm not afraid of repairing it if it's localized.
P 0300
"Borrowed" from AutoCodes
Possible causes
The discombubulator has come loose from the enaculabreator causing the windingulator to be out of ballance.
Plugs or coil would set a specific cylinder code most likely. Sounds like carbon buildup. Could be low fuel pressure, need scanner to check. I cleaned the carbon on mine at 80k. Put a catch can on at the same time.
if it’s driveable, check for it poping out of second gear. My second disappeared at about 95k.
I'd put good money on the back of the intake valves being carboned up. Maybe a 3 hour job to fix it. Looks stock, haggard, and has high miles so it's a safe bet they've never been done.
Edit: If you grab it change to a stud kit to make life easier when you pull the intake manifold. Also check the injector seals for evidence of leaking. They're a known weak point and it'll cause that code or a ZZB.
I'm resisting the urge to leave work early and grab it out from under you. I want to turn something like that into a monster track rat. Though I probably wouldn't live to see tomorrow if SWMBO found out.
randomly-occurring air leak causing occasional random misfire. look for torn air intake boot between MAF and TB.
In reply to The0retical :
Why don't you just do that and "hide" it at my place- hell, we can even put the title in my name to be really sneaky about it
¯\_(ツ)_/¯ said:In reply to The0retical :
That would be the 2nd GRMer-owned MS3 residing at another GRMer's place that I'm aware of. We may be able to start some kind of oddball trend/cult here.
In reply to Pete Gossett :
They'd both be black too! Though I know the other one is significantly less rusty.
