unevolved
unevolved HalfDork
10/6/10 10:26 p.m.
So I'm moving to an internal powered antenna in my RX7, and I've been looking for a source for some plugs to fill the hole in the body where the OEM antenna was. After a little bit of searching, I decided to share what I found with y'all.
Scroll down to the "Flexible Plastic Plug" section, it seems like exactly what I (and a few others with the same problem) need.
http://www.mcmaster.com/#snap-in-plugs/=95ytq2
ddavidv
ddavidv SuperDork
10/7/10 5:34 a.m.
That's what I used on my E30 race car, works perfectly.
triumph5
triumph5 HalfDork
10/7/10 6:48 a.m.
I keep forgetting about them; spent a half-hour browsing. Kept the wallet in the other room...
Toyman01
Toyman01 SuperDork
10/7/10 6:55 a.m.
I used steel and a welder to fill mine.
spin_out
spin_out Reader
10/7/10 7:12 a.m.
I use "FTD" stickers. (That I borrowed from a friend :)
Hocrest
Hocrest Reader
10/7/10 7:31 a.m.
You can get metal caps at Lowes or a plumbing supply store. They're made to fill extra holes in sinks.
16vCorey
16vCorey SuperDork
10/7/10 8:24 a.m.
Toyman01 wrote: I used steel and a welder to fill mine.
I painted my Rabbit in a pole barn that was semi-recently built. The plugs for the antenna and all four side marker light holes were the metal circles that you pop out of steel outlet boxes like these: I found them on the floor, tacked them into place, and smeared a little bondo over them. Worked perfectly.
Giant Purple Snorklewacker
10/7/10 8:33 a.m.
I used black racer's tape. There are enough holes in the bottom to let the water out so it really was just an aesthetic issue. I hate to have an unsightly blemish on my svelte E30.
uqGfu7Q4uq0lVlki96YgQwmYXzLDW4PvQAVTT6jeGURPzwODnIgfXCzilRldenVt
