SyntheticBlinkerFluid
5/21/16 8:46 a.m.
So the wheels on our 2013 Focus are the premium 18 inch polished wheels. I'm doing the brakes on the car today and I noticed that the wheels are pretty dirty. Is there a good product to clean these wheels with? There is no clearcoat that I can see.
chiodos
chiodos Dork
5/21/16 8:53 a.m.
Unless its powdercoat or your supposed to re polish them all the time theres almost always clear coat on them. I have no brands to suggest other than just get some thats clear coat safe. Better safe than possibly flakey wheels ya know?
stuart in mn
stuart in mn UltimaDork
5/21/16 10:17 a.m.
Always start with mild cleaners, and only work up to harsher products if it's necessary. Good old soap and water is a first choice. As mentioned, they are most likely clear coated.
4Msfam
4Msfam Reader
5/21/16 2:45 p.m.
Simple Green? Only if it has a clear coat.. I like it for my car.
fasted58
fasted58 UltimaDork
5/21/16 2:53 p.m.
Soap and water w/ a wheel brush.
stuart in mn
5/21/16 4:22 p.m.
I use Simple Green a lot and like it, but it will damage clear coat on wheels if you aren't careful - either rinse it off quickly, or use it in a diluted form.
Jumper K. Balls
Jumper K. Balls UberDork
5/21/16 4:50 p.m.
Remember, caustic based degreasers (simpler green, super clean and the like) WILL darken aluminum. Depending on the surface of the aluminum it can happen very quickly
This was a fresh piece of alloy sheet that had the protective plastic film peeled off moments before soaking it into a gallon of hot tap water with 2 cups of super clean in it. It was in the solution for 2 minutes  photo 20150302_112834_zpsfdx6cjg9.jpg
This water neck was sandblasted and tossed into the same solution. It did this in under a minute because of the sandblasted surface.
Acid based products will brighten aluminum. It bleaches it out. Aluminum Brightener available at auto parts stores is very quick acting stuff.
Start with a basic soap with a neutral PH. If that doesn't cut it I would switch to a solvent.
clutchsmoke
clutchsmoke SuperDork
5/21/16 5:04 p.m.
Dawn and water?
Dusterbd13
Dusterbd13 PowerDork
5/21/16 8:21 p.m.
Jumper K. Balls wrote: Remember, caustic based degreasers (simpler green, super clean and the like) WILL darken aluminum. Depending on the surface of the aluminum it can happen very quickly This was a fresh piece of alloy sheet that had the protective plastic film peeled off moments before soaking it into a gallon of hot tap water with 2 cups of super clean in it. It was in the solution for 2 minutes  photo 20150302_112834_zpsfdx6cjg9.jpg This water neck was sandblasted and tossed into the same solution. It did this in under a minute because of the sandblasted surface.  photo 20150302_112817_zpsricbglul.jpg Acid based products will brighten aluminum. It bleaches it out. Aluminum Brightener available at auto parts stores is very quick acting stuff. Start with a basic soap with a neutral PH. If that doesn't cut it I would switch to a solvent.
I may have to try this with the valve covers we talked about. Still haven't had a chance to send you them.
motomoron
motomoron SuperDork
5/21/16 9:58 p.m.
There are no production car aluminum wheels anymore that aren't coated or surface-converted in some way. 3-piece race wheel shells and kart wheel shells are about all that's raw.
I'm a convert to Sonax wheel cleaner. It's not caustic. Spray it on yellow, it turns bloody/purple and converts the metallic components of brake dust to something else, chemically. Depending on which wheels I may agitate with a soft brush to get in the corners and between spokes, like on BBS/BMW style 5s. Then hose off.
I like it so much I got a 5 liter refill from Amazon when it was on sale. It's great stuff.
SONAX!
Slippery
Slippery Dork
5/21/16 10:13 p.m.
motomoron wrote: There are no production car aluminum wheels anymore that aren't coated or surface-converted in some way. 3-piece race wheel shells and kart wheel shells are about all that's raw. I'm a convert to Sonax wheel cleaner. It's not caustic. Spray it on yellow, it turns bloody/purple and converts the metallic components of brake dust to something else, chemically. Depending on which wheels I may agitate with a soft brush to get in the corners and between spokes, like on BBS/BMW style 5s. Then hose off. I like it so much I got a 5 liter refill from Amazon when it was on sale. It's great stuff. SONAX!
I love Sonax, did not know it came in a 5lt refill. Off to Amazon.
iSOIISihzlaNTrsEvSGHaRvf8kLD4gUcbb8cP2uleJsNWLZeTlyTvwOEloALfjfk
