Wrxbart
Wrxbart
7/15/20 4:10 p.m.
do you still make the adapter kit?
precisionchassis said:
  • You use the stock Boxster cooling system. It's more than adequate, even on the base models that only have 2 radiators
  • You CAN use the stock Subaru turbo exhaust manifolds. It's just a matter of some custom exhaust plumbing to the turbo from there
  • The intercooler for a street car would be an air/water type and would be located in the rear trunk. No direct air flow needed for the intercooler itself. The factory center radiator up in the front is used as a heat exchanger.
  • The adapter kit DOES exist to mate a Subaru engine to a Boxster 5 or 6 speed transaxle, and so does the engine mounting system. You use stock Boxster axle shafts.
Sounds like I need to update the web site with some more current information. There are two "street versions" of the conversion happening right now in-house and the finished products will be a representation of the kit that will be sold.
RX Reven'
RX Reven' SuperDork
7/15/20 4:25 p.m.
uaUCZbm6PfXSrMaAt3NijAhkFq6pUXXEDII4S2JNcWoyPm7Jc5aoMvQ2WKo1eGNu
