slantsix
slantsix HalfDork
3/7/22 2:06 p.m.
Hello GRM Hive,
What is a fiberglass safe chemical paint stripper to use on a panel?
Thanks for the help!
Greg
Mr_Asa
Mr_Asa PowerDork
3/7/22 2:16 p.m.
Lotta variables.  Know what the resin used to hold the fiberglass in place was? Use the wrong stuff you might cause damage at a molecular level.
I'd probably lean towards mechanical means, myself.
3/7/22 2:32 p.m.
Talking about fiberglass repair, just dropping this here in case it helps:
cyow5
cyow5 Reader
3/7/22 2:36 p.m.
I found good luck with strippers containing "methylene chloride" which is now banned because people died. Everything else I have tried was, at best, 3x worse. As stated above, this also depends on your fiberglass. I had some sections repaired with polyester that it would eat right up. It didn't dissolve the epoxy sections. This worked out great for me since I was removing the bad polyester repairs anyways.
This was the good stuff: http://kleanstripauto.com/products/aircraft-paint-remover
I'd give their latest recipe a shot since you know they at least tried to baseline the old stuff, but I don't know how it'd do.
Mr_Asa
Mr_Asa PowerDork
3/7/22 2:36 p.m.
This inspired me to just f'ing get to work on The World's Most Expensive Boat,  so yes it is helpful
3/7/22 2:41 p.m.
In reply to Mr_Asa :
Rock on.
Mr_Asa
Mr_Asa PowerDork
3/7/22 2:45 p.m.
There is a parts cleaner out there that still has the good stuff in it.  All sorts of other things in it, but still has the MeC.
Berryman Chem Dip #0905, from what I can find online.
slantsix
slantsix HalfDork
3/7/22 8:06 p.m.
Mr_Asa
I really don't know - unknown composition Brand new Fiberglas hood that has been in the rafters for over 10 years..
I bust it outta storage to get it on my car, get it all Test fitted, aligned, minding the gaps etc, cleaned, and prepped. Laid paint on it and have fisheyes!  Gotta strip that new paint off and try again. I have no Idea where the contamination came from, but it looks awful.
So I do not know what resin / gelcoat formula is under there.. Sorry.
@David S. Wallens
Thanks for sharing -I did watch that one a while back but its worth a good review again.
Greg
slantsix
slantsix HalfDork
3/7/22 8:23 p.m.
Mr_Asa
@David S. Wallens
Greg
TurnerX19
TurnerX19 UltraDork
3/7/22 10:20 p.m.
Imbeded release agent from when it was first molded is the probable cause for the fish eyes. Most likely polyester resin and I would not use MeC on it. The paint with fish eyes will come off easier than good paint too. The real problem here is going to be getting it clean enough to take fresh paint. Mechanical sanding is likely to push the contaminent further into the surface, and not remove it enough.
californiamilleghia
californiamilleghia UltraDork
3/8/22 1:13 p.m.
Since they tell you to wax the molds before starting , does that get into the surface of the finished part ?
if so how to you solve that problem ?
Thanks
slantsix
slantsix HalfDork
3/8/22 4:45 p.m.
Thanks
Yes That's what I am wondering??!?
TurnerX19
TurnerX19 UltraDork
3/8/22 4:51 p.m.
In reply to californiamilleghia : and Slantsix
 The release agents and waxes wash off reasonably well when the parts are new, but are never removed thoroughly by the manufaturer. The OP's part was left unfinished in storage so all bets are off. Heat cycles and random abrasion play an ugly part here. The normal wax removal cleaning sequence is particularly ineffective if there has been any abrasion.
Mr_Asa
Mr_Asa PowerDork
3/8/22 4:58 p.m.
Mechanical removal down to fiber, new gelcoat top coat, prep that?
Best I have.
MMIs2EQ2nnmaz2NDEguQIAk77WJ3fWIJOeuowGugPAw349YS6cTmcG1iNYxwdXdG
