Carl Heideman
Carl Heideman
7/19/22 11:49 a.m.
Where do chassis come from?
It’s easy to have a kind of stork-myth response to this question: Chassis simply come from somewhere else. They’re born on high-tech assembly lines heavily staffed with robots performing strange, pneumatic choreography. They’re delivered into you…
RonB001
RonB001 New Reader
9/6/22 8:35 p.m.
In #2, you say "use a crisscross pattern for your tack welds."
In the diagrams for #2, it looks like you are talking about diagonally opposite corners of a frame section.
In the pictures and notes for the rest of the article, though, it looks more like you are talking about the corners of one end of a tube.
I can see how there could be reasons for both, so how do you figure out which to do first?
gearheadE30
gearheadE30 Dork
12/19/22 8:59 a.m.
This was a very timely article, since I'm welding patches in to the floor of the 325es this week. Unfortunately I started yesterday....but hey, they say lessons learned firsthand are the ones that stick with you the best...
  • welded next to a magnet, which resulted in welding the magnet itself and some real weird arc behavior.
  • didn't alternate where I was welding well enough, resulting in some warping
  • one patch panel had a bit of a gap, which of course immediately blew through
  • didn't quite get all the underbody coating ground back far enough, resulting in contamination
With all the mistakes out of the way, hopefully tonight goes better. Unfortunately these lessons mean I need to re-make at least one patch panel...
Y6vEDAWnZO21cKMqT9jDc5BXQqZuIZjtoE2xnzmbi40W2Ibuo9Kc4CaSe2y22CZN
