Is there a formula? I'm sure there is, and some 3-dimensional trig would certainly help you find it.
One of the first things you'll need is how many degrees away from straight "1/2 lock" is.
Thinking aloud... I'm conjecturing that if you could turn the wheel 90 degrees, the camber would equal your original caster... I'm further conjecturing that the camber would "advance" smoothly from the static camber value at straight forward to the new camber value at 90 degrees rotation (which, from prior conjecture, is equal to caster). So, if you knew the angle of steering, you could calculate that as a percentage of 90 degrees, multiply that by the difference between camber and caster angles, add that to your static camber, and get your camber at that point in steering.
EDIT: I figured I'd add in some example math...
If the alignment specs were 1 degree camber and 4.5 degrees caster, and assuming we were turning the wheel 20 degrees...
20/90 is .2222, or 22.22%
Multiply that by the difference in values, 3.5, to get .7777
Add that to your original camber value to get 1.77 degrees,
Of course, the above totally disregards any geometry changes that may be happening due to suspension travel... with a mcpherson strut, you're losing camber as the strut compresses, so you'd have to take that into consideration for an outside wheel. It also assumes that your alignment is done at 0 toe.
Again, that's just me postulating, I'm totally accepting of the fact I may be 100% wrong.
