Jay
Jay Dork
5/20/10 10:10 a.m.
This might be really dumb, but... the "blower position" control in my car is served by five vacuum lines, about 1/4" in diameter. I've now taken that switch out. Can I drive the car with these lines disconnected or will it cause a vacuum leak at the engine?
grimmelshanks
grimmelshanks Reader
5/20/10 10:27 a.m.
plug them
Strizzo
Strizzo SuperDork
5/20/10 10:27 a.m.
it will be a leak, albeit probably a small one, usually there is a vacuum reservoir with a check valve in case you're accelerating and need to change the setting. also without the check valve it will go to the default (usually defrost) every time you hit the gas.
Jay
Jay Dork
5/20/10 10:41 a.m.
Okay, thanks guys. Here comes the hot glue gun.
Strizzo
Strizzo SuperDork
5/20/10 10:45 a.m.
actually, i think you'll only need to plug the "source" line, not all 5. presumably the vacuum comes from the engine, then is distributed by the switch to select the various settings.
procainestart
procainestart Dork
5/20/10 11:04 a.m.
What Strizzo said. Just find/plug the vacuum line from the intake to the vac. accumulator; don't mess with the lines behind the dash.
eGCoqNpXRowLJPoI28H0vd260MT7Fd5sKcpnjCHMgMZaqkOTnwlywBP6SwxjumRn
