Ovid_and_Flem
Ovid_and_Flem HalfDork
4/5/17 10:23 a.m.
It's time to start finishing my Porsche 911 rally tribute build. What material do you use for mud flaps? Where is it available? I want to use black, not white. Any photographs of your own creation or suggestions on construction appreciated.
Thanks in advance
¯\_(ツ)_/¯
¯\_(ツ)_/¯ SuperDork
4/5/17 10:35 a.m.
I've used ABS plastic, flexible cutting mats, "urethane" Rally Armor knockoffs, and rubber. The harder materials will crack when it gets cold and they get pelted with rocks, the softer ones are easy to rip off by accident. My recommendation would be to just get universal rubber ones, trim them to fit, and use large washers or large headed rivets to mount them.
My current rubber ones, $15/pr on Amazon:
Ovid_and_Flem
4/5/17 10:39 a.m.
In reply to ¯_(ツ)_/¯:
Thanks...was hopping you would weigh in. Love your build.
¯\_(ツ)_/¯
¯\_(ツ)_/¯ SuperDork
4/5/17 10:42 a.m.
In reply to Ovid_and_Flem:
Thanks! By my count I've killed upwards of ten mudflaps at this point so I felt qualified to comment
I did also have a set of the RallyArmor Basic flaps that held up fine on a rallycross car, if you wanted to spend a little more money and like the look of their stuff- I still think they would end up destroyed on a stage rally car, so I prefer to use cheaper stuff since it's a consumable at that point.
Ovid_and_Flem
4/5/17 10:49 a.m.
I'm only pushing about 250 hp with 205 70 15 tires so maybe whatever I come up with will survive. I doubt there's a rally cross within 700 miles of me so I won't be competing regularly. But I do have a lot of country dirt roads and levies to run around on in Mississippi period LOL
eastsidemav
eastsidemav SuperDork
4/5/17 11:08 a.m.
I've built a set from a $20 semi truck mudflap. They were pretty durable, but I only used the car for Rallycross, not stage rally.
captdownshift
captdownshift PowerDork
4/5/17 11:17 a.m.
Ikea flexible cutting boards + black plastidip
amazon link to boards
FooBag
FooBag Reader
4/5/17 11:18 a.m.
I made mine out of a couple of these poly truck mud flaps. Link Depending on how large of mud flaps you're making, one might be sufficient. I went quite large with mine due to FWD.
4/5/17 11:21 a.m.
I hear conveyor belt material works great.
edizzle89
edizzle89 Dork
4/5/17 11:27 a.m.
FooBag wrote: I made mine out of a couple of these poly truck mud flaps. Link Depending on how large of mud flaps you're making, one might be sufficient. I went quite large with mine due to FWD.
and if you have company with a big fleet or a heavy truck shop near by you can probably get some for free that have been ripped off of trucks and cant be used again, they usually end up just throwing them away
petegossett
petegossett UltimaDork
4/5/17 1:24 p.m.
I had a set of the cheap Rally Armor flaps on my Hyundai Acc(id)ent that held up surprisingly well throughout 100,000 of the worst abuse you can imagine. That would probably be the cheap & easy solution for you.
4/5/17 2:04 p.m.
I've got a set of flaps that were supplied by rallylights.com. It's a thick, flexible plastic, about an order of magnitude more robust than a cutting board. They survived two Targa Newfoundlands and a bunch of track days.
HFmaxi
HFmaxi New Reader
4/5/17 7:16 p.m.
polyurethane mud flaps from rallylights are going to be better than all the other suggestions by far. I bought mine years ago: http://www.rallylights.com/mfmat-mud-flap-material-black-or-red-per-square-foot.htmlhttp://www.rallylights.com/mfmat-mud-flap-material-black-or-red-per-square-foot.html
don't bother with rally armor or cutting boards. the trick with the flaps is that you need something like a leather punch or a small tube sharpened on one side to make the holes, otherwise they can be cut with sharp shears.
irish44j
irish44j UltimaDork
4/5/17 8:17 p.m.
¯\_(ツ)_/¯ wrote: In reply to Ovid_and_Flem: Thanks! By my count I've killed upwards of ten mudflaps at this point so I felt qualified to comment I did also have a set of the RallyArmor Basic flaps that held up fine on a rallycross car, if you wanted to spend a little more money and like the look of their stuff- I still think they would end up destroyed on a stage rally car, so I prefer to use cheaper stuff since it's a consumable at that point.
We have the Rally Armor "SUV size" basics on the e30, and the've held up for 5 years of rallycross and what...3 rallies now with no sign of any problems. But we don't shoot gravel as hard as you do ;)
irish44j
irish44j UltimaDork
4/5/17 8:19 p.m.
HFmaxi wrote: polyurethane mud flaps from rallylights are going to be better than all the other suggestions by far. I bought mine years ago: http://www.rallylights.com/mfmat-mud-flap-material-black-or-red-per-square-foot.htmlhttp://www.rallylights.com/mfmat-mud-flap-material-black-or-red-per-square-foot.html don't bother with rally armor or cutting boards. the trick with the flaps is that you need something like a leather punch or a small tube sharpened on one side to make the holes, otherwise they can be cut with sharp shears.
Nice to see you on here, Kevin
griffin729
griffin729 HalfDork
4/5/17 8:29 p.m.
petegossett wrote: In reply to Ovid_and_Flem: I had a set of the cheap Rally Armor flaps on my Hyundai Acc(id)ent that held up surprisingly well throughout 100,000 of the worst abuse you can imagine. That would probably be the cheap & easy solution for you.
You can add another 18 months and 15k miles to these flaps and they're still holding up fine. Though, my commute is on much friendlier roads than Pete's was. Still haven't made a rally cross with 'em. The group running at the Badlands died right as I bought the car from him. So, closest now is Western Ohio or Detroit regions.
NGTD
NGTD UberDork
4/5/17 9:56 p.m.
1 semi-truck mudflap = 4 rally car mudflaps.
VdEX5Ik5Q3gz4s2UqKhAOgUAPkohSrVKwD3OAFFIxIUuKV10gWLaJufhXjyYCwBJ
