Hey guys,
First off I have a friend with a 92 Chevy Cavalier with the 2.2 litre engine. About 2 months ago it wouldn't start for him, and he is just now getting around to trying to fix it. He replaced the coil packs/computer module that sits under the packs, and still no start. Any particular place we can start looking? It cranks, and we can hear the fuel pump, but no fire. He said when it first started acting up it would start every now and then, but not since. Any help would be appreciated.
Question two regards my 04 Suburban. Just tonight the check engine light came on. No idea why, but can I gather any codes from it without a reader? I know on my 01 Dodge Ramwagon I could cycle the key a few times on and off, and then it would give me a error code which I could look up on the interwebz. Any such luck with the Chevy? FYI I did fuel up tonight, but the fuel cap is tight.
Any help is appreciated.
Chris
Check the fuel pressure. The fuel pump may be working, but maybe not enough. Might even be flooding.
Have you checked the wiring going to the coil pack? Did you check for power after the coil pack? Sounds like he has been blindly changing things out.
No clue about the code, but I would suggest getting a BlueTooth OBDII reader. I have one and it is just fantastic to have. No more wondering about the codes. Until then, tighten the gas cap.
Could be a fpr on the cav.
Suburban, az/advance for a scan for free. Just write down the codes and figure out later.
The cav is a simple beast. What dont you have? Spark, fuel pressure, injector pulse? Find that out, thats your first step to troubleshooting. Keep in mind that paying a garage is usually money better spent than throwing parts at it.
Let the parts store scan the burb and tell us the code.
Car repair is all about diagnostics, yet it's the hardest part of fixing it. Even with older cars like his, he still needs to know what isn't working. If he doesn't take it to a repair shop, tell him to test the battery without a load, with a load with an ohm meter, then check the starter for free at Autozone/Advance Auto Parts.
If you fix your own Suburban, it's time to look for an OBD II scanner.
There is a crank position sensor under the ignition module. Check that.
patgizz
PowerDork
4/14/15 7:17 a.m.
was going to say that. if no spark with new module and coils, i'd test that.
take burb to parts store and have them scan free.
I do fix the suburban myself. I will go to the local flaps to get a scan. I also think I will get a Bluetooth scanner at some point. What is a good cheap one to buy?
My friend with the cavalier mentioned that his brother who has an automotive repair shop mentioned it could be the crank position sensor and that they are a nightmare to replace. I don't know where it is, but it doesn't look like much of anything on the car is tough to get to.
Chris
It's under the ignition module. The issue is that they sometimes get stuck in the block and break when you try to remove them. Then you have to drop the oil pan to get them out.
luckily, the oil pan takes about 10 minutes to get off on those cars.
Advance auto read the code as C0223 abs signal erratic right side.
Why would that trip the check engine light and not the brake warning light?
Chris
Check engine light went out on my way home from advance auto.
it trips check engine light for "global obd2" witch covers everything from abs to transmissions. The brake light will only come on for fluid and pedal pressure problems as far as i know.
Clean the rust off the hub where the sensor mounts and go about the rest of your day.
Hal
SuperDork
4/14/15 8:29 p.m.
Probably already done since the light went out. But I would check the wiring to the wheel sensors.
