stan_d
stan_d Dork
5/17/12 1:16 p.m.
I am putting together a setup using lots of used stuff looks like should be in 300 dollar range.
100 for turbo 60 two sticks 2 1/2 pipe 10' long 35 electric pump Front mount intercooler 50 Semi truck radiator hose for couplers 11 foot Supply and return lines?? Fount a tank for 20 if I go stand alone oil system then I would need a cooler to.
Think this is very possible, why does sts charge 4k?
How many would cry "bs"? This is coming on my challange car.
Grtechguy
Grtechguy PowerDork
5/17/12 1:40 p.m.
$100 turbo is well used? and you are not paying for R&D, Employees, and packaging.
N Sperlo
N Sperlo UberDork
5/17/12 1:45 p.m.
Giving me a hermitage. Where are your commas? What the hell is a hermitage and why is it in my Autocorrect log?
K, I think I understand more now... But I'm going to read it ten times before I can put it together.)
m4ff3w
m4ff3w SuperDork
5/17/12 1:54 p.m.
I think he hit enter after each item in his list - but GRM doesn't work that way.
What kind of oil pump are you planning on using?
ShadowSix
ShadowSix HalfDork
5/17/12 2:03 p.m.
N Sperlo wrote: Giving me a hermitage. Where are your commas? What the hell is a hermitage and why is it in my Autocorrect log? K, I think I understand more now... But I'm going to read it ten times before I can put it together.)
http://www.thehermitage.com/
Why, it's the home of President Andrew Jackson, just minutes from the excitement of downtown Nashville and the glitz of the Grand Ole Opry!
bigbens6
bigbens6 Reader
5/17/12 2:05 p.m.
sounds cool... what motor/turbo combo and car is this going on?
evildky
evildky Dork
5/17/12 2:08 p.m.
wait a minute, any turbo on that toyota truck will be a rear mount! you should do a front mount turbo
Raze
Raze SuperDork
5/17/12 3:43 p.m.
totally possible, I priced a twin turbo rear-mount system for a northstar a few years ago and came up under $900, including a high temp return oil pump, turbos, tubing, couplers, clamps, hangars, and a small intercooler, some of it was new, the turbos were of course used...
stan_d
stan_d Dork
5/17/12 7:39 p.m.
Built another v8 240sx. I don't know if my brother will bring the truck this year.
Trans_Maro
Trans_Maro SuperDork
5/17/12 8:52 p.m.
stan_d wrote: why does sts charge 4k?
Are you familiar with the concept of "paying for knowledge"?
4K means you buy the kit parts and bolt them on.
$100 means figure it out yourself.
TeamEvil
TeamEvil New Reader
5/18/12 12:26 p.m.
Is there a power benefit to fitting the turbo at the rear, or is this because of room constraints in the engine bay?
jere
jere New Reader
5/18/12 12:33 p.m.
In reply to TeamEvil:
Small engine bays
jere
jere New Reader
5/18/12 12:36 p.m.
I would find a way to mount the intercooler on the way back up to the motor (laying down flat with ducts in and out) or just leave it out and run water/meth. You are going to be waiting for ever for boost to kick in if the IC is front mounted.
stan_d
stan_d Dork
5/18/12 2:17 p.m.
The v8 has 318 ft lbs of torque at 1800 rpm now I have a small intercooler figure something is better than none. The bov I have opens under 5 inmg so cruise it will be drawing in fresh filtered air.
Harbour freight sells stainless steel pumps for 35 I'll just carry a spare.
wu5uAR8J1dRtIZAcL9KKXmaLuPWQxDijXrQgrfIoOaUduh30fmjUIylPfOo6e2sq
