Mmadness
Mmadness HalfDork
8/29/14 6:13 p.m.
When rebuilding brake calipers on a new (four months old) car, do the pistons need to be replaced as well or will it do just fine with new seals only?
stan_d
stan_d Dork
8/29/14 6:17 p.m.
Is there any rust ? pistons look good no grooves . If all looks good I would use them.
Wally
Wally MegaDork
8/29/14 6:18 p.m.
If they are still in good shape I wouldn't worry about it. Just curious, why do four month old calipers need replacing ?
Mmadness
Mmadness HalfDork
8/29/14 6:24 p.m.
Wally wrote: If they are still in good shape I wouldn't worry about it. Just curious, why do four month old calipers need replacing ?
The brake cooling ducts were not installed before the track day
Can the pistons melt at some point? The plain rotors were cracked from all of the heat and the corner workers said the rotors were glowing orange in the braking zones.
Kenny_McCormic
Kenny_McCormic PowerDork
8/29/14 7:20 p.m.
If they're steel pistons I highly doubt you hurt them.
oldtin
oldtin UberDork
8/29/14 9:27 p.m.
What's the symptoms/diagnosis? You mentioned the rotors are toast. What's the word on calipers? Stuck, leaking?
Mmadness
Mmadness HalfDork
8/30/14 6:06 a.m.
oldtin wrote: What's the symptoms/diagnosis? You mentioned the rotors are toast. What's the word on calipers? Stuck, leaking?
Overextended and leaking.
oldtin
oldtin UberDork
8/30/14 11:58 a.m.
I would think just seals - with the thought the pad wear and cracked rotors allowed the pistons to overextend.
lEUFWFuFdnRvcoTgzc6t5xjS8MSiwrOeVAw6gMYCGDTvqURyjwENo6i1wuYTSJ1e
