pete240z
pete240z SuperDork
10/29/11 5:08 p.m.
Can I do this at home? Anybody try this? Powder Coating? Is there a way to do this or leave it to the professionals?
Check Datsun Roadster startup @ 0.35
http://www.youtube.com/watch?v=pJ21aKtpmW8
porksboy
porksboy SuperDork
10/29/11 5:16 p.m.
how about this? http://www.tcpglobal.com/spraypaintdepot/vht-wrinkle-plus.aspx
Keith
Keith SuperDork
10/29/11 5:28 p.m.
We used to do it with paint. I seem to recall heat lamps.
Now we have it done by a powder coating shop. It's more consistent and a whole lot easier!
Zomby woof
Zomby woof SuperDork
10/29/11 5:39 p.m.
porksboy wrote: how about this? http://www.tcpglobal.com/spraypaintdepot/vht-wrinkle-plus.aspx
That's what I used for my GT.
I baked it in the oven while my wife was out. It's held up fine. Just make sure your prep is good.
porksboy
porksboy SuperDork
10/29/11 6:08 p.m.
Looks like they have a primer for it.
1988RedT2
1988RedT2 Dork
10/29/11 6:55 p.m.
I used to do production paint for a tool company many years ago. They had a black crinkle finish paint that they dried under heat lamps. No idea who made it. You'd spray it on kinda heavy and put it under the lights. Crinkle!
familytruckster
familytruckster Reader
10/29/11 8:21 p.m.
plenty of companies make it, available at any retail auto parts place. I used plasticote or VHT IIRC on my bmw VC. Put it on thick, toss it in oven.
erohslc
erohslc Reader
10/29/11 9:48 p.m.
Yeah, standard industrial coating, used to do a ton of it at a factory. Thicker, even coats are best. Too thin, and it wont crinkle properly, leaves flat spots, then you have to strip it and re-do.
Carter
pete240z
pete240z SuperDork
10/29/11 10:37 p.m.
"Bake at 200°F (93°C) for 20 minutes"
yeah, I will find out when the wife is going to be out of town.....
Per Schroeder
Per Schroeder Technical Editor/Advertising Director
10/30/11 6:29 a.m.
Your wife's hair dryer will work too.
JoeyM
JoeyM SuperDork
10/30/11 7:04 a.m.
pete240z wrote: "Bake at 200°F (93°C) for 20 minutes" yeah, I will find out when the wife is going to be out of town.....
Keep an eye out for old ones that are being thrown out. I picked one up down the street from me - literally less than a block away - from a house being remodeled. I was originally planning to strip it for sheet metal to use on the car, but the owner of the home said it works, and that the missus just wanted more modern appliances. My shed is already wired for 220 because of the welder, so I just put it in there....haven't tried it yet, but I intend to use it for powder coating.
If you have the room for an extra oven in the garage/shed, they are probably not that hard to find....
DILYSI Dave
DILYSI Dave SuperDork
10/30/11 8:25 a.m.
I used eastwood powder, and then put it on the mill to re-cut the raised logo.
mad_machine
mad_machine SuperDork
10/30/11 8:28 a.m.
any idea on fumes?
Zomby woof
10/30/11 8:58 a.m.
Minimal. The smell of the oil (cooking in the oven) was worse than the paint.
JoeyM
JoeyM SuperDork
10/30/11 9:17 a.m.
DILYSI Dave wrote: I used eastwood powder, and then put it on the mill to re-cut the raised logo.
That looks gorgeous....now I'm feeling sad that I don't have a Mill. the same treatment would look great on the cover of my L24
porksboy
porksboy SuperDork
10/30/11 10:01 a.m.
Not to hi jack but.
Dave, whats that engine in?
I would really like to do that in my CRX.
DILYSI Dave
10/30/11 10:50 a.m.
91 CRX
It was my $2003 challenge car and my daily driver for the next 5 years.
Vigo Dork
10/31/11 1:01 p.m.
VHT wrinkle plus NEEEEEEEEEEDDDDDDSSSS heat. I have tried doing the same paint to the same part three times and ended up annoyed every time.
Learn from my mistakes and use a LOT OF HEAT.
You also need to be a decent sprayer because you need to put it on HEAVY without having runs. For awkwardly shaped parts (like what i was doing) this means you need to turn the part and hold it in different positions to spray that heavy on the different sides without having runs.
If you spray it too thin it wont wrinkle. If it doesnt get hot it wont wrinkle.
Just dont get overspray on it like i did. She definitely noticed.
Cone_Junky
Cone_Junky HalfDork
10/31/11 1:05 p.m.
<img src="Photobucket" />
Dupli-color makes a spray paint wrinkle finish with no oven needed. I haven't found it in red though. I do recommend painting it in direct sunlight to "encourage" it to wrinkle faster/better. 2-3 thick coats looks great when done. Very durable.
Keith
Keith SuperDork
10/31/11 1:55 p.m.
JoeyM wrote: That looks gorgeous....now I'm feeling sad that I don't have a Mill. the same treatment would look great on the cover of my L24
You can do the same thing with a scotchbrite pad on a rotary tool.
PseudoSport
PseudoSport Reader
10/31/11 2:18 p.m.
I used Dupli-color and a heat gun for mine.
p1010345
Without the heat gun I got a very uneven wrinkle finish.
turboswede
turboswede SuperDork
10/31/11 2:25 p.m.
Yep:
Red engine enamel, no masking, dried in the sun, cleaned up afterward with a jitterbug sander, various grits and a polishing wheel.
triumphcorvair
triumphcorvair New Reader
10/31/11 3:40 p.m.
I had to re-read who the author was twice on this one to make sure it wasn't me because I've been thinking about doing the same thing! My valve cover is already wrinkle finished black but I want to paint it red. I guess my dilemma is do I paint it with a red wrinlkle paint or could i use just a regular red paint? Any suggestions?
oldeskewltoy
oldeskewltoy HalfDork
10/31/11 3:57 p.m.
JoeyM
JoeyM SuperDork
10/31/11 5:52 p.m.
Cone_Junky wrote: <img src="Photobucket" /> Dupli-color makes a spray paint wrinkle finish with no oven needed. I haven't found it in red though. I do recommend painting it in direct sunlight to "encourage" it to wrinkle faster/better. 2-3 thick coats looks great when done. Very durable.
I haven't used the wrinkle version, but have used Duplicolor engine paint....the normal version looked good but was not real durable
feaczJmZya9EeTT0j9R9Pr9EGPBeMCpwalLhWf7vMMayggRgRn9qVuKHOJN25sVC
