My RX-7 has a lot of dried-up tree sap on the hood and roof, as you can see here:
I'm tired of people telling me to clean the bird E36 M3 off of my car, and I have some free time while I wait for the next batch of repair parts to come in. I was looking at the DIY clay bar topic and was wondering, will that get the sap off?
Hal
HalfDork
12/9/08 9:38 p.m.
Haven't tried the DIY type clay bar. But I have found that the commercial clay bars are the easiest way to remove tree sap.
I use the clay bar from Griots Garage and have their special Pad/holder
Clay and pad to use on my buffer.
Never tried this on paint before but peanut butter takes it off skin quite well. It might be worth a try.
The clay is bitchin, it took some nasty overspray off of my car.
Saps and resins mights be soluble in rubbing alcohol so maybe give that a try. They do make some stuff to remove it. I think the clay is a good idea though, like Hal said.
Per Schroeder
Technical Editor/Advertising Director
12/10/08 12:55 a.m.
I've had good luck using a sharp razor blade.
Carefully (!) scrape parallel with the paint surface (but above the paint surface). If the sap is dried enough, it'll 'pop' off in a big chunk. The remaining bits can be removed with kerosene/yourfavoritesolvent.
I always used gasoline on a rag to get it off.
Josh
Reader
12/10/08 11:51 a.m.
I use Goo Gone, it takes some elbow grease but seems to do the best job of removing sap with minimal impact on the paint.
WD-40 will do it
if not try kerosene
So how do I get a poor sap out of my car? (rimshot!)
SoloSonett wrote:
WD-40 will do it
if not try kerosene
WD-40 has kerosene in it, SIHBT
My dad swears to god that Vaseline will take it right off. I've never tried it, but he is pretty knowledgable on these things.
Try a plastic razor blade (yes they exist!). WD40 will remove it as well but is kinda messy IMHO.
Josh
Reader
12/10/08 1:08 p.m.
Salanis wrote:
Shotgun.
Dude. Everyone knows those are for breaking lugnuts.
Lacquer thinner or denatured alcohol, and if it's on paint, be sure to re-wax that spot.
