Titan4
Titan4 New Reader
12/17/19 12:06 p.m.
So, my offspring ran over something in the road (don't know what) resulting in a blown front tire and a hole in the gas tank (2016 Toyota Rav4).  The car was towed to the dealer.  I can get a salvage yard gas tank put in or I can get a new tank for $500 more.  What's the downside to the salvage gas tank?  I'm guessing rust and crud in the tank that shakes loose when it's removed could lead to plugged fuel filter / fuel pump and further trouble but I'm not sure.  Should I spend the extra for the new tank?
L5wolvesf
L5wolvesf Reader
12/17/19 12:17 p.m.
New one on Rockauto is under $300
dculberson
dculberson MegaDork
12/17/19 12:27 p.m.
I would have no problem with a used Toyota OEM gas tank for a 2016 car. It's probably a lot better than the new aftermarket ones available. I don't imagine there's any rust or crud in the tank in a 2016!
Titan4
Titan4 New Reader
12/17/19 1:22 p.m.
In reply to dculberson :
Yeah, I wouldn't expect much crud in there either but I'll admit I haven't looked into many new(ish) gas tanks.  That was about the only thing I could think of as a downside to a used tank.  I suppose that there may be older RAV4s of that generation that could donate a tank (not sure when that generation started) but still they shouldn't be more than another couple of years older.  I just wanted to see if that was what other people expected and to see if anyone knew of any other potential issues.  Thanks.
1988RedT2
1988RedT2 MegaDork
12/17/19 2:09 p.m.
How much is the used tank?  At $270 plus shipping, I'd probably opt for the new one from Rockauto.
Titan4
Titan4 New Reader
12/17/19 2:22 p.m.
In reply to 1988RedT2 :
Used is $170 and new OEM from Toyota is $650.  I'm having the dealer do this so I don't know that an aftermarket piece from Rockauto is an option.
1988RedT2
1988RedT2 MegaDork
12/17/19 2:40 p.m.
Got it.
2016 is new enough to be most likely fine, and if the dealer is doing the work, I'd say you are correct.  Price seems reasonable.  Good luck!
A 401 CJ
A 401 CJ Dork
12/17/19 3:21 p.m.
New tank, used tire.   ;-)>
7BWxGYzLaKqeePT9IYCYEzrMmN9YPBNflMQYb0EBD3OGvPVnnza8TMW1zOVeZKa2
