Wally
SuperDork
8/21/08 2:25 a.m.
Someone decided to shoot out some windows by the train station tonight so I find myself needing to replace a couple windows on the Cavalier. I figure the door window should be a fairly simple bolt on job but I can't figure out the quarter window. Is it glued, screwed, some kind of trick molding? It's a 99 Cavalier 2 door (yeah, I know). I'd like to get new glass in it soon before someone takes the radio and removes the last little bit of joy from my ride to work.
ddavidv
SuperDork
8/21/08 4:47 a.m.
Probably glued in. Not a fun job if it is. Worth paying someone to do it for you. Be sure to shop around as glass replacement is a very competitive business and prices can vary quite a bit.
TIP:
Do Not let the replacement firm , remove the old one.
DIY...
They will use the wire "cheese cutter " method.
It's very efficient at removing the glue and glass.....
and paint.
Always a place for rust to start.
If your not in the "rust belt" it's not as big an issue.
But ask anyone driving a car with rust around a windshield,
"How long ago did you have that glass replaced?"
ugh.. the quarter windows are the most expensive and hardest to replace due to the glue.
I agree with Sonett.. go over it yourself and remove the broken glass before taking it to the glass shop.
So how many cars lost glass?
mtn
PowerDork
4/17/12 9:11 a.m.
FYI, madmachine, this post is 4 years old and pulled up by a canoe last night.
Maybe a variant of this in the meantime?
