914Driver SuperDork
3/1/10 12:28 p.m.
How about a spring pin? They are usually press fit into place as they are expandable.
Plan B:
Find a drill bit that fits snugly into the hole, cut the drill shank off and cut it into two pieces the length you need. At that size the shank is the same diameter as the cutting edge.
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=spring+pin&op=search&Ntt=spring+pin&N=0&sst=subset
mkiisupra
mkiisupra New Reader
3/1/10 1:34 p.m.
I had a similar problem on my Datsun Roadster Nardi wheel. Just get the closest roll pin in size that is just a bit bigger (sounds like you found it) and either squeeze/vice pin together just a hair or gently open the hole just a bit, and 'screw' the roll pin in. Usually the metal that the pin fits into is aluminum and is quite easy to fit a slightly larger pin in. All parts available at ACE/True Value Hardware, much more fun than shopping for hardware online. $0.02, hope it helps.
Eric G
914Driver SuperDork
3/1/10 2:01 p.m.
iadr wrote: I am not 100% sure it's tight enough to locktite, plus the hole has grease/oil in it. Lots of time with brake clean and compressed air, and I might make it clean enough, but it's still a little loose.
Lock Tite is anaerobic, it only hardens in an area where there's no air, you want JB Weld.
Redrilling a hole for specific applications is not "Hack". It's "custom made, hand tooled by our skilled craftsman" and worth another $10 on the bill.
Dan
czS8JUTXd0ImfGRzkEmABjWKHdXpbsK3J4oVXGbyU5ProYPpXR0oRoOGeIiMCsY0
