Rufledt
Rufledt Reader
3/29/10 11:20 p.m.
Saturday I went to a dealership nearby to test drive an Evo X with the prospect of buying one in a couple months. Turns out i ended up buying an RX-8 R3 . Go figure eh? Well actually i tested an RX8 a few days earlier and had an idea that i might go that way... Anyhoo its a 2009 so i got an insane deal with all the rebates plus a bunch off on top of that, and an extended warrantee and all that stuff that's not very interesting when you're holding the keys to a new car. pic:
I'm super excited about it and i put like 30 miles on today after i picked it up at 5. What i would like to know is any information you guys have for me to do proper maintainance. i know it uses oil and i need to check it when i gas up, the manual says 5w20 but the service guy at the dealership stressed not getting synthetic oil. then there is the shut off thing. the manual says not to shut it off until it warms up, the service guy at the dealership says if i need to shut it off before it warms up i should rev it to 3K and hold it there for 12 seconds, and the saleslady said to always rev to 5-6K for 3 seconds, blip the throttle and then let idle for 3 seconds before shutting it off. what would you guys recommend? anything else a rotary noob should know? i ask especially because i've alwasy been interested in rotaries but never really researched them because i didn't think i was gonna buy one, and here i am. Thanks for your help guys! -Paul
unevolved
unevolved Reader
3/29/10 11:47 p.m.
Never ever ever drive it a short distance and shut it off without letting it properly warm up. I'm not 100% sure if RX-8s are the same way, but RX7s will flood. And unlike a piston engine, they won't unflood themselves when left alone.
Make sure and redline it once a day. You know, to clear the carbon out.
Keep an eye on the oil levels, it's natural for them to burn oil, they use oil to cool the rotor faces.
I'm a new rotorhead too (my car's about 25 years older than yours, though) and those are some things I've learned that should apply to yours too.
Mazdax605
Mazdax605 Reader
3/30/10 5:42 a.m.
All I can say is that car is absolute crap,and you should give it to me so you don't have to put up with it.
Seriously sweet car man. I had an 04 in Nordic Green for 1 year on a lease,and I loved it. Yours is way cooler in that colour, and the R3 package is sweet. The front grille/bumper looks different than mine did. Did Mazda update the body some over the years,or is that part of the R3 package?
Someday I will get another one in white this time,but that blue is changing my thinking a bit. Good luck,and rev the snot out of it.
Chris 78 RX-7 GS,74 REPU,74 RX-4 coupe
BoxheadTim
BoxheadTim Dork
3/30/10 6:37 a.m.
The synthetic vs non-synthetic discussion is one a good way to start the Mother Of All Flamewars on most rotary forums. I'll stay out of that and just mention that if you want to use synthetic, make sure that it's low-ash when it burns.
As the other say, don't start it for a minute, then turn it off, it's a good way to flood it. Warm up thoroughly, redline regularly, keep an eye on the oil level, job's a good 'un.
RossD
RossD Dork
3/30/10 7:35 a.m.
Sweet car. I didnt think a modern fuel injection system could flood an engine piston or otherwise?
BoxheadTim
BoxheadTim Dork
3/30/10 7:38 a.m.
It very well can on a rotary. They dump large amounts of fuel in to get the engine going, due to the combustion chamber shape.
pilotbraden
pilotbraden New Reader
3/30/10 7:57 a.m.
I have a2009 rx-8 and a 1985 rx-7. I have flooded the rx-7. The procedure for shut down while cold is to hold 3000-4000 rpm 2-3 seconds then shut down without changing throttle position. I have never had a problem with the rx-8 using this procedure after driving 7-8 blocks and stopping for breakfast on my way to work in 20 degree weather.
It is a great car enjoy it.
klipless
klipless New Reader
3/30/10 8:25 a.m.
Never, ever, ever shut it off when the engine is still cold. Just last month I spent two solid days trying to unflood my 04 because I made that stupid mistake. It took a new set of spark plugs to get it going again. I'm sure I took some serious life off of my starter motor and battery cranking it as much as I did. I'm sure the cat was not to happy about it either. So seriously, never shut it off when cold.
I use traditional dead dino in my engine. There's no reason to use synthetic, it burns through oil decently quick. I think I add a quart every 1500 miles.
And rev the piss out of. Nothing like a good old Italian tune-up to keep Wankle's happy.
cwh
cwh SuperDork
3/30/10 8:33 a.m.
"Italian Tune-up" Never heard that one before.
EricM
EricM Dork
3/30/10 8:40 a.m.
Boost in, Apex Seals out.
Oh, and from what I hear ( I haven't owned one) get use to buying gas for it.
Otherwise, the people I know who do have one, like them alot. ( I know two people who own one.)
pilotbraden
3/30/10 8:42 a.m.
On my rx-7 I have a switch cutting power to the fuel pump. I shut it down by shutting off the fuel pump. Shutting down at higher rpm blow any extra fuel out of the engine as it spins down. If it does flood merely change 1 spark plug per combution chamber and it fires right up. Ihave done that on the rx-7 very easily, it appears to be a bit more complex to reach the plugs on the rx-8.
klipless
klipless New Reader
3/30/10 8:51 a.m.
pilotbraden wrote: it appears to be a bit more complex to reach the plugs on the rx-8.
They're not too hard to get to. Just pull the front left wheel and use it as a seat. Remove a small splash guard and they're right there. I use a 12" socket extension and a wobble joint to get to them. It took me a half hour the first time I did it, and that included walking a couple blocks to the hardware store to buy the right spark plug socket, 13/16" IIRC. Oh, and anti-seize is your friend.
A good how to.
dyintorace
dyintorace Dork
3/30/10 8:57 a.m.
klipless wrote: Never, ever, ever shut it off when the engine is still cold. Just last month I spent two solid days trying to unflood my 04 because I made that stupid mistake. It took a new set of spark plugs to get it going again. I'm sure I took some serious life off of my starter motor and battery cranking it as much as I did. I'm sure the cat was not to happy about it either. So seriously, never shut it off when cold. I use traditional dead dino in my engine. There's no reason to use synthetic, it burns through oil decently quick. I think I add a quart every 1500 miles. And rev the piss out of. Nothing like a good old Italian tune-up to keep Wankle's happy.
I find it amazing that a brand new car requires this amount of special care and handling.
klipless
klipless New Reader
3/30/10 10:12 a.m.
Wonkothesane wrote: Long story short: If you move the car a short distance (I.e.: It's 20 degrees out and you move it from the road to the driveway), hold the revs at 2500-3000 and turn the key off and you'll NEVER have to worry about the problem.
That's how I flooded mine. Almost that exact scenario, it might have been 21 degrees though. Held the revs when I keyed off, and when I came back to start it the next morning, nuttin.
Cleaned up old plugs (28k miles) and reinstalled, no dice. Had some new ones laying around that I was going to install when I did my next oil change, and it worked like a charm.
I wouldn't say NEVER, maybe ALMOST NEVER.
pilotbraden
3/30/10 10:20 a.m.
In reply to klipless:
On the rx-7 you open the hood and there they are. I have changed all 4 in under a minute. In comparison the rx-8 is a pain
Rufledt
Rufledt Reader
3/30/10 10:30 a.m.
thanks everybody! that's all very helpful! this jives pretty well with what i've been reading, and i can tell i'm gonna love it. As for frequent oil/gas fill ups, I also drive a 1987 E-150 with many miles of heavy towing, so it burns oil faster than this rotary should. either way, i'm used to checking the oil ALL the time. i just got myself a quart of oil to keep in the the rx8, but i keep a jug of oil in the van at all times! and then gas, well combined city/hwy where i tried to drive nice i got 11 mpg, so i'll be super happy with 16-22. not that i care all that much about mileage.
and as for all of these procedures and special care, i'm a nerd, so i love extra procedures. And it's a new car, so it should get special care
the redlining it thing, uh, that won't be a problem...
Winters will be interesting here in wisconsin, but i don't really want to drive this in the salt so its good i'm keeping my van. Whats should i do if i want to park it for a few months? any special procedures? With my van my dad used to just unplug the battery and to hell if it has a dry start next time. it's already worn out, and after about 30 minutes the different colors of smoke go away since i've had it i've never let it sit for more than a week without going somewhere, though.
Oh and someone asked about the front bumper being different. It is different, and its an R3 thing. looks pretty good i think, though i think all RX8's look pretty good!
Rufledt
Rufledt Reader
3/30/10 10:45 a.m.
one more question! i've never really researched rotaries much beyond the basic how they work stuff. Where should i go/what books should i read and so on to brush up on rotaries?
Knurled
Knurled New Reader
3/30/10 10:52 a.m.
  1. Add a half ounce of two-cycle oil per gallon of fuel. The oil metering pump does not add enough oil. This is worth a little power in addition to longer engine life.
  2. Don't use 5W20 - use 10W30 at a minimum, 20W50 in the summer. It's worse for fuel economy but the RX-8 oiling system is shortchanged. It is essentially the same oiling system as an '86 base model.
  3. Synthetic oil is fine. There is one brand of synthetic that was not compatible with rotaries and Mazda had to blanket-statement against synthetics. Use Mobil 1. I have for years with no issues.
Knurled
Knurled New Reader
3/30/10 10:54 a.m.
dyintorace wrote: I find it amazing that a brand new car requires this amount of special care and handling.
It's funny - there is a TSB regarding VW/Audi products having the same cold start flooding issue as rotaries. People expect a VW to not run half the time, though.
JohnGalt
JohnGalt Reader
3/30/10 10:57 a.m.
Knurled wrote: 2. Don't use 5W20 - use 10W30 at a minimum, 20W50 in the summer. It's worse for fuel economy but the RX-8 oiling system is shortchanged. It is essentially the same oiling system as an '86 base model. 3. Synthetic oil is fine. There is one brand of synthetic that was not compatible with rotaries and Mazda had to blanket-statement against synthetics. Use Mobil 1. I have for years with no issues.
Don't know about an oil that heavy, 5w30 or 5w40 is heavy enough, some cars have trouble getting the oil pressure up in hot climates, some people switch back to a lighter oil in the winter.
Don't want to cause the mother of all flame wars but Mobil 1 IS the oil Mazda had so much trouble with. Not saying that you are an idiot or that Mobil 1 is the destroyer of apex seals but it is the oil mazda had problems with 10-15 years ago.
How Stuff Works has a good article and describes it in good detail.
Link
Rufledt
Rufledt Reader
3/30/10 12:02 p.m.
ok good to know! i already have a quart of 5w20 but i'll get some 10w30 and just rotate which one i use when i top off the oil until i run out of 5w20. so that means i should change the oil myself so i can make sure it gets 10w30?
now i should go pick up some two-cycle oil... more driving to places.. oh darn. haha
BoxheadTim
BoxheadTim Dork
3/30/10 12:12 p.m.
I'd get synthetic two stroke oil as that's usually designed for mixing ratios of 1:100 or more - the usual lawn mower stuff isn't and I'm not sure if that does any good.
pilotbraden
3/30/10 12:21 p.m.
For the best protection there is a block off platefor the oil metering pump. You then run the lines into a reservoir containing quality 2 stroke oil, and fill the sump with whatever synthetic you want. Home built aircraft use these. I believe the entire kit cost $100-$120 dollars. I am planning on this for mine. On the rx-7 i disabled the pump and run premix 150-1 penzoil marine, I also run the same oil in my 2-stroke motorcycles.
Rufledt
Rufledt Reader
3/30/10 3:20 p.m.
thanks for the extra info! i'll definitly look into that kit. i also saw that video with the 4 rotor Rx8! sounds awesome! looks out of my price range, though... and i can't even immagine the fuel consumption!
Knurled
Knurled New Reader
3/30/10 7:18 p.m.
Wonkothesane wrote: Not to be pedantic, but an '86 base model has the same oiling system that a 86 "luxury" model has, as well as the 87-88 Turbo'd models, and essentially the same system the 89-91 had, with the exception of a mechanical oil metering system as opposed to the newer electronically activated one.
The non-turbo oil pump is a lower volume part than the turbo pump. The RX-8 also runs fairly low oil pressure relative to, say, the FD. Oil pressure is paramount to keeping a high RPM rotary happy, as is oil viscosity.
The 5w20 vs. 10w30 thing doesn't actually have anything to do with the 8's oiling systems, a lot of car manufacturers switched their specs in the US to run 5w20 instead of 10w30 as a "standard" because of emissions. If it takes less energy to move the oil around (lighter weight oil), there's less work on the engine and therefore easier to control the output.
....and better fuel economy. Automakers would sell their grandmothers for another tenth of a MPG average.
An interesting note about this is on newer Lexuseesesesese and Mazdas (probably more but I don't know of any specific examples off hand), if you check out an identical owners manual US spec vs. Japanese spec, the Japanese ones will call out 10w30 while the US ones use 5w20. There is no mechanical difference between the two.
The same goes for Fords and Hyundais and everyone else who specifies 5W20. The engines are the same everywhere, they just want to squeeze out a tiny bit more fuel economy.
I use 20W50 in my rotaries and change it when it starts to smell like fuel, which is about 1000mi. But then my rotary is the anti-Renesis and at idle and light cruise it probably misfires as often as it fires, so can you say "fuel wash"?
nwJOIVSZyOFfFH6jSjabdicBrs2pi4JWiLipbmqZdTye7YPMMId2OleaADT8rPbe
