BillL223
BillL223
11/7/12 7:18 a.m.
On page 139 of the December issue there is a picture of a power tool used to remove pickup rubber. What kind of tool is that? I got a hugh amount last weekend at NJMP and would like to remove before my next DE.
Ranger50
Ranger50 UltraDork
11/7/12 7:44 a.m.
It is one of those oscillating things....
http://www.lowes.com/pd_349164-70-PC250MTK_4294707786__?productId=3370044&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=
motomoron
motomoron Dork
11/7/12 11:11 a.m.
What is it w/ NJMP and OPR?
The first time I was at Thunderbolt I must have gathered literally a couple pounds of rubber on the Star Specs I use to drive to and from and for the first couple learning sessions. I put my RA1s on and scraped between sessions for hours. Uggh.
iceracer
iceracer UltraDork
11/8/12 8:16 a.m.
I just used a propane torch and a putty knife.
Toyman01
Toyman01 PowerDork
11/8/12 8:45 a.m.
I use asphalt and HP.
stafford1500
stafford1500 New Reader
11/8/12 11:40 a.m.
Try this...
Tire grinder disc
Giant Purple Snorklewacker
11/8/12 11:43 a.m.
I use a warm-up lap. It is practically free.
friedgreencorrado
friedgreencorrado PowerDork
11/8/12 11:57 a.m.
Giant Purple Snorklewacker wrote: I use a warm-up lap. It is practically free.
The pic in the magazine was taken at the SCCA autoX championship.
11/8/12 12:00 p.m.
I don't cotton to anything that limits me to less than 2 minutes of driving in an 8hr day. Shorten it by 2 minutes and you don't even need a car!
dculberson
dculberson SuperDork
11/8/12 12:34 p.m.
stafford1500 wrote: Try this... Tire grinder disc
I don't believe I've seen a power tool warning quite that stern:
"NOTE: Use extreme caution - serious injury can result from the use of discs. When powered by a buffer, these discs can cut your arm or leg off."
stafford1500
11/8/12 1:10 p.m.
I don't believe I've seen a power tool warning quite that stern: "NOTE: Use extreme caution - serious injury can result from the use of discs. When powered by a buffer, these discs can cut your arm or leg off."
Yeah the warnings do kinda get your attention...
I suspect there may be at least one dead customer that made the warnings appear.
I would not even think of putting that near a tire!!
codrus
codrus Reader
11/8/12 4:58 p.m.
If a set of Hoosier A6s is a thousand bucks and good for 80 runs, then a warm-up lap is $12!
Last time I did this I used a heat gun and a metal putty knife, but now my heat gone has gone missing.
turboswede
turboswede PowerDork
11/8/12 5:39 p.m.
In my experience, I've found that the el ess juan is one of the best tools for rubber removal. The el ess juan has been used by countless professionals over the years and has been proven to safely remove that pesky tire rubber buildup quickly and easily. Now this amazing breakthrough is available to you.....
In the Mazda Miata:
Get yours today!
BillL223
BillL223 New Reader
11/11/12 12:57 p.m.
I had a ton of pickup, we were the first to run NJMP after Sandy and I guess between a green track and the normal abrasion of NJMP there was a lot of rubber. I did buy a Porter Cable oscillating multi-tool Model PCE605 and used the flexible scraper that came with it and it worked as I hoped. They have a rigid scraper which is a little wider and I think I'll try one of them next.
Vigo SuperDork
11/11/12 1:08 p.m.
Even without the text that thing looks friggin dangerous.
Birthdays
g6ctu2nP3PT8jR2rFtyA4X5e4Imiskdl0mJlgMJNoc3gRW7ntMqIlJpf2v32ezFp
