Javelin
Javelin MegaDork
9/3/13 6:12 p.m.
A stupid cheap one of these popped up right by my house, and I am sorely tempted. I've never ever owned a SAAB before and I always wanted to. What am I getting into here?
SlickDizzy
SlickDizzy UberDork
9/3/13 6:16 p.m.
900 classic or NG 900? Either way it is your typical chain-driven 16v four cylinder (or 8v if it is a real early classic turbo). Not a walk in the park but not a VR6 either, there is decent room to work if nothing else.
Jerry From LA
Jerry From LA Dork
9/3/13 6:22 p.m.
The motor's in backwards and the tranny's underneath it. Is it an 8-valve or 16-valve turbo? Is it a classic 900 or "new" 900? Only Elring head gaskets (the SAAB oe) are worth a damn. Check the turbo for wear because there's no water cooling and SAAB original owners are not all that great at changing oil (GRM board members and their families excepted of course). While you have it torn down that far, take the opportunity to replace the front crank seal (the one against the firewall). They leak like sieves. One good thing: It'll be the easiest clutch job you ever do.
Javelin
Javelin MegaDork
9/3/13 6:27 p.m.
In reply to SlickDizzy:
It's the old school looking one:
Jerry From LA
Jerry From LA Dork
9/3/13 6:34 p.m.
That's referred to as the classic 900 or C900 in saabnet.com parlance. it's a 16-valve turbo. saabnet.com is a good place to start. Find the 16-valve Bentley manual for this car. Totally worth it.
Jerry From LA
Jerry From LA Dork
9/3/13 6:36 p.m.
Oh yeah. Torque-to-yield head bolts.
mad_machine
mad_machine MegaDork
9/3/13 6:59 p.m.
I did the HG on my 91 2.1. It was not a hard job, but some of the bolts that hold the head on are a bit hard to get to. I refer to the ones against the firewall that bolt "up" from the block to seal the chain galley.
Otherwise, it was not a horrible job
Jerry From LA
Jerry From LA Dork
9/3/13 7:24 p.m.
Yeah, they just squeezed that wider head in there so those are a pain.
procainestart
procainestart Dork
9/3/13 10:16 p.m.
Buy it - that's a good price.
Post here if you get it; I can puke out a bunch of info on doing this job on a c900.
BTW, that red in '90 will take some work, but it's not clearcoated, IIRC, so you can bring it back.
HappyAndy
HappyAndy SuperDork
9/4/13 8:24 a.m.
I've done a few, no big deal. BTW, I don't think that they use torque to yeild bolts. If you want to use new bolts, I would not discourage you, but mine sees 18 psi of turbo pressure & 6000+ rpm regularly on reused bolts. You do need to retorqe the bolts periodically.
IMO, the most enjoyable FWD car to drive of all time.
Javelin
Javelin MegaDork
9/4/13 11:18 a.m.
In reply to Jerry From LA, mad_machine, and HappyAndy:
Thanks!
In reply to procainestart:
I got the original red paint on the Javelin (73) to come back, so yeah, I'm feeling good about my chances on this red.
BTW all, it's a 5-speed manual and $500. Going to look at it tonight.
HappyAndy
HappyAndy SuperDork
9/4/13 11:30 a.m.
Look for rust around the battery tray, and under the lower control arm mounts, especially the passengers side.
Good luck.
ls1fiero
ls1fiero Reader
9/5/13 8:13 a.m.
I have a nice Talladega Red 91 doors and hood for cheap if you want them.
ls1fiero
ls1fiero Reader
9/5/13 8:17 a.m.
I also have a spare Bentleys Manual.
bgkast
bgkast HalfDork
9/5/13 12:06 p.m.
So are you the proud new owner of a busted SAAB?
mad_machine
9/5/13 7:50 p.m.
HappyAndy wrote: I've done a few, no big deal. BTW, I don't think that they use torque to yeild bolts. If you want to use new bolts, I would not discourage you, but mine sees 18 psi of turbo pressure & 6000+ rpm regularly on reused bolts. You do need to retorqe the bolts periodically. IMO, the most enjoyable FWD car to drive of all time.
from when I did the HG on my 2.1. It was torque to spec.. then quarter turn, then quarter turn.. so I think that qualifies as torgue to yeild?
procainestart
procainestart Dork
9/5/13 9:10 p.m.
I have a scan of an old (March 1992) Technical Tips brochure for Saab techs that says that, "as a general guideline, the bolts should be used (torqued) no more than 5 times," for B2x2 engines. The brochure also says that there's no other spec, e.g., length; it says only to replace if one exceeds length of the others, is thinner, or cannot be torqued to spec.
The instructions in the following link, by a Saab tech, say that it's rare to find a bolt that can't be re-used:
http://townsendimports.com/Web/engine_folder/headgasket90016v.htm
I've r&r'd headgaskets without replacing the bolts on three c900 Turbos - haven't had any issues yet.
Javelin
Javelin MegaDork
9/6/13 11:29 a.m.
Awesome! Thanks for the tips. Looking at it tonight or tomorrow.
Javelin
Javelin MegaDork
9/9/13 11:30 a.m.
Well, I bought it. It fires right up. Runs okay, but won't idle. Shows no signs of a HG failure. I drag it home tonight.
Swank Force One
Swank Force One MegaDork
9/9/13 11:40 a.m.
I'll take "massive vacuum leak" for $800, Alex.
Javelin
Javelin MegaDork
9/9/13 11:44 a.m.
In reply to Swank Force One:
Yup, that's what I'm thinking, too.
dabird
dabird Reader
9/9/13 12:14 p.m.
Sounds like a bad AMM
Powar
Powar Dork
9/9/13 12:53 p.m.
dabird wrote: Sounds like a bad AMM
Or an intercooler pipe popped off...
Javelin
Javelin MegaDork
9/9/13 12:58 p.m.
Huh. Turns out my SAAB is a 16V SPG!
Powar
Powar Dork
9/9/13 1:01 p.m.
Javelin wrote: Huh. Turns out my SAAB is a 16V SPG!
Cool, just because of the body cladding, wheels and springs. Unless its very nice, they don't seem to be anymore valuable than a normal 900T.
I've stripped and scrapped two SPGs.
Where are the pics?
USD6mcyT3kFfz6fe4aK7LtumfrIhsZYOL3pR9VHzcsTHlo37PfDNmRCjNI0WEeTZ
