914Driver SuperDork
7/15/09 1:18 p.m.
Power vs weight vs outside dimensions.
Ford guys say they can build a righteous 5.0, but there's an awful lot of aftermarket Chevy stuff out there. Who to believe?
What do you think? Who can make more power for the size?
Dan
Nashco
Nashco SuperDork
7/15/09 1:24 p.m.
You can build a very powerful SBF. You can build a SBC with the same power for cheaper. Being the most popular engine ever made has its benefits. The overall size isn't drastically different, so unless you literally can't fit a SBC then what does it matter?
Bryce
mw
mw Reader
7/15/09 1:24 p.m.
I;m not a v8 guy, but from what I've heard, if outside dimensions are an issue, go with ford. If not, go with chev.
Tom_Spangler
Tom_Spangler Reader
7/15/09 1:51 p.m.
Nashco wrote: You can build a very powerful SBF. You can build a SBC with the same power for cheaper.
My understanding is that this isn't as true as it used to be. The explosion in popularity of the 5.0 Mustang made for a whole lot more cheap SBF parts than existed before that. At one time there were 10+ companies making cylinder heads for those engines, though I don't know how that market is now.
I'd say it comes down to personal preference and how well each would fit your particular application.
oldtin
oldtin New Reader
7/15/09 2:13 p.m.
Pretty comparable. The ford is about 100 lbs lighter - alum. heads can drop another 40 lbs. - you can get big power out of either or leave them understressed and they last a long time. The 5.0 is shorter, narrower and not as tall, but not by a huge margin in any direction - like an inch. My challenge car is an mgb with a 5.0 - the weight ended up more of a factor than cost or hp potential comparing to an sbc.
m4ff3w
m4ff3w Dork
7/15/09 2:24 p.m.
oldtin wrote: Pretty comparable. The ford is about 100 lbs lighter - alum. heads can drop another 40 lbs. - you can get big power out of either or leave them understressed and they last a long time. The 5.0 is shorter, narrower and not as tall, but not by a huge margin in any direction - like an inch. My challenge car is an mgb with a 5.0 - the weight ended up more of a factor than cost or hp potential comparing to an sbc.
How does the SBF compare in weight with the Al blocked Gen 3 & 4 engines?
P71
P71 SuperDork
7/15/09 2:25 p.m.
Hot Rod or Car Craft did an article a few years ago and found that now it's cheaper to build a SBF than a SBC. You can't go wrong either way, they are both excellent engines. As pointed out though the Ford is smaller and lighter, though it will not hold to up to as much power on a stock block. Roller cam "5.0"'s are much easier to find and provide even more bang-for-the-buck.
ScottRA21
ScottRA21 New Reader
7/15/09 2:50 p.m.
Ford small block?
http://www.airflowresearch.com/articles.php
Scroll to the bottom, and tke a quick look through the "Ultimate Guide to 5.0 Cylinder Heads"
EXTENSIVE does not begin to describe this article. Measuring, flowtesting, and dynoing up to 8 different heads, on 4, very different blocks (over 30 head swaps in total).
It was done in 2001, but it does give you an incredible insight into what it takes to build what sort of power. And it was done by a third party, not AFR themselves.
oldtin
oldtin New Reader
7/15/09 2:52 p.m.
SBF weighs in at 485 w/iron heads - 445 w/alum LSx avg about 415 I bought a 5.0 ho for $79. Can't really do that with an LSx yet.
John Brown
John Brown SuperDork
7/15/09 3:05 p.m.
If you are tight on length but have width you use a Chevrolet. If you are tight in width but have length use the Ford. If you can fit either but want the absolute most power buy the Chevrolet.
Nashco
Nashco SuperDork
7/15/09 3:31 p.m.
P71 wrote: Hot Rod or Car Craft did an article a few years ago and found that now it's cheaper to build a SBF than a SBC.
Did they ever meet Andy Nelson?
RossD
RossD Reader
7/15/09 3:59 p.m.
One thing to consider is location of distributor (if you're using one) The ford's is in the front and the chevy's is in the back of the block. Somthing to consider if the back of the engine will be under part of the cowl/scuttle.
Trans_Maro
Trans_Maro HalfDork
7/15/09 4:01 p.m.
John Brown wrote: If you are tight on length but have width you use a Chevrolet. If you are tight in width but have length use the Ford. If you can fit either but want the absolute most power buy the Chevrolet.
Yup..
The 351W fit in my '48 Chevy fleetmaster better than the SBC did so I went with the blue oval.
It's narrower by just enough that I can keep my factory steering column, if I used a SBC I'd need a MII front suspension and new steering column.
Shawn
oldtin
oldtin New Reader
7/15/09 4:07 p.m.
ford ends up with a front sump - something else to consider on crossmember clearance.
Chris_V
Chris_V SuperDork
7/15/09 4:09 p.m.
when building either, more cubes equals more power. A 5.0 has a hard time cresting 347 cid. A 350 Chev of course starts out there, and factory parts go over 400 cid without changing exterior dimensions.
But, the 5.0 (or earlier 302) will fit in some tight areas, and can make more than enough power for not a lot of money anymore, especially carbed.
Jensenman
Jensenman SuperDork
7/15/09 4:40 p.m.
I'm a SBF man mostly due to the head design. As noted by others, it fits in some pretty tight spots too when compared to the SBC.
SBF's can be made rear sump with a Bronco or Fox body Mustang oil pan and pickup, the 351W can be made rear sump with a Fox body swap oil pan sold by Ford Racing.
Don't take this to mean SBC's are junk because they aren't.
Travis_K
Travis_K HalfDork
7/15/09 4:57 p.m.
Chevys will make more power without breaking the block, the ford ones will split in half. Chevys have the distributor at the back, so that can be annoying sometimes. Fords have better heads, and widely available EFI parts, chevys anything other than the TBI ones get stripped at the junkyard pretty fast.
Trans_Maro
Trans_Maro HalfDork
7/15/09 7:13 p.m.
oldtin wrote: ford ends up with a front sump - something else to consider on crossmember clearance.
There are different pans, my Windsor came out of a Crown Vic Interceptor. Rear sump.
Shawn
maroon92
maroon92 SuperDork
7/15/09 7:25 p.m.
SBFFTMFW! Sorry, but i grew up a Ford kid... In this case i think its firestone/michelin, holley/edelbrock, valvoline/quaker state. Pick what you like, and be prepared to defend it to the death in a room full of car guys.
P71
P71 SuperDork
7/15/09 7:36 p.m.
Screw em both, AMC all the way!
fiat22turbo
fiat22turbo SuperDork
7/15/09 8:21 p.m.
Is it too late too mention the 340 or 360? Lol
NOHOME New Reader
7/15/09 10:28 p.m.
And to prove that the world is getting smaller, the LS heads from GM bolt on to the Ford 302.
You are on your own for a manifold.
dyintorace
dyintorace Dork
7/15/09 10:37 p.m.
Another consideration is that the SBF sounds better uncorked than the SBC...IMO.
My first car was an '87 5.0 with Flowmasters and nothing else. I still miss that sound.
wheels777
wheels777 HalfDork
7/15/09 11:11 p.m.
Owned both, own both, raced both, won with both. $/HP go SBC. Better head design with ports that can make more hp. Better Intake/exhaust flow ratios. Better oiling system. More head bolts allow for better head clamping force. 4 bolt mains allow better bearing clamping force. Block can take lots more HP. Internal balanced except 400 and one piece rear seal engines. Super availability for aftermarket parts.
SBF has some good features, good valve angle, clean straight castings, good bore:stroke ratio for small engine, short deck allow light rotating assembly weights. Engine weighs 40 pounds less........ But the exhaust ports suck. Oil pump pick-ups draw oil against direction of acceleration. Narrow block make for poor intake runner length dimensions - 4 long and 4 short - unless you use a EFI set-up. External balanced with diferent pulley bolt arrangements and balance weights.
Bottom line...build what you want. They are both decent pieces.
ReverendDexter
ReverendDexter HalfDork
7/15/09 11:53 p.m.
I'm shocked at how civilized this discussion is
zOob8Z5TB1PvAgh9uvBHfNBUGxS2aVTlKX41imJwLVIL7ey9ZRx7CSU1p19wTJiU
