Are there any other wheels that work with an SHO?
The absolute best looking wheels for a Taurus SHO are the Volvo Pegasus R wheels. IIRC, you'll need wobble bolts, but they'll fit. I always wanted to put a set on mine when I had it, but I was pretty broke at the time.
I remember seeing pics of them on 2nd Gen SHOs on SHOForum when I used to frequent that board.
16 by 7 inch with a 5 by 108mm bolt pattern. New Thunderbird 02 and newer will work. Thunderbird supercoupe wheels are also this size. 04 and later Mercury Sable has a 16 by 6 inch. 99 and later Lincoln LS and 93 and later Mk VIII. Jaguar S-type from 99 and later and the X type from 02 and later. Lots more if you can handle 15 inch. Got a Supercoupe just pulled in to the local Pick-N-Pull!
http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm
Bruce
