redvalkyrie
redvalkyrie Reader
2/4/17 12:53 p.m.
That's an interesting idea. The cam and dizzy rotor rotate 360 degree in synchronization, correct? You could replace the four magnetic posts representing the four cylinders with a single one that shows the MS3 complete cam rotation has occurred...am I right on this?
ae86andkp61
ae86andkp61 HalfDork
2/4/17 11:31 p.m.
Yarp, that's the way my MS3 4A-GE is set up; crank wheel plus modified distributor with one post serving as a cam sensor.
It should be mentioned that the mods also included adding an aftermarket sensor to the stock distributor housing. After a few frustrating attempts to reverse engineer OE sensors to get it to play nice with the Megasquirt, I like the new sensor with a full spec sheet, plus the relative ease of getting replacements down the road if needed.
In theory it may have to crank a little longer to sync before firing up, but in practice I haven't noticed a big difference.
redvalkyrie
redvalkyrie Reader
2/5/17 2:13 a.m.
ae86andkp61 wrote: Yarp, that's the way my MS3 4A-GE is set up; crank wheel plus modified distributor with one post serving as a cam sensor. It should be mentioned that the mods also included adding an aftermarket sensor to the stock distributor housing. After a few frustrating attempts to reverse engineer OE sensors to get it to play nice with the Megasquirt, I like the new sensor with a full spec sheet, plus the relative ease of getting replacements down the road if needed. In theory it may have to crank a little longer to sync before firing up, but in practice I haven't noticed a big difference.
Do you have pics of your setup? Could you point me to the sensor you finally went with?
KnfvQL9ax2zJLSKTj1Wkqo7RtnHeylPp1v1og4wpIMjZVNELIzd3gmHwK0idhDTH
