Lof8
Lof8 Dork
10/20/18 3:39 p.m.
Pretty bummed. Wanted to get my trans bolted up to the LS1 today and found my clutch disk a bit damaged from shipment.  should I go ahead with this or return it?  I don’t want to do this job twice.
BoxheadTim
BoxheadTim MegaDork
10/20/18 3:40 p.m.
I would return it. That doesn't look like a recipe for long life to me.
stuart in mn
stuart in mn UltimaDork
10/20/18 3:40 p.m.
I'd send it back.
Dr. Hess
Dr. Hess MegaDork
10/20/18 4:10 p.m.
If it was mine, it'd go back.
Suprf1y
Suprf1y UltimaDork
10/20/18 4:15 p.m.
I doubt that it would affect the life of the disc, but you did pay for a new one and that's what you should get. I would send it back.
Knurled.
Knurled. MegaDork
10/20/18 4:20 p.m.
I wouldn't be concerned so much about that little bit of fraying, as much as the fact that something hit it hard enough to damage it like that in the first place.  There's a good chance that it is warped and you might have disengagement issues.
Another vote for send it back.
EastCoastMojo
EastCoastMojo Mod Squad
10/20/18 4:22 p.m.
Yep, I wouldn't want to do that job twice either, and once you install it they ain't taking it back.
fasted58
fasted58 MegaDork
10/20/18 4:33 p.m.
Return it
You paid for new not scratch n dent
Lof8
Lof8 Dork
10/24/18 4:26 p.m.
Got the replacement kit today and it was equally as poorly packaged and damaged the same way. Hopefully 3rd times a charm.
But upon closer inspection of the pressure plates, they seem to be weighted differently around the perimeter. Do you think I need to make sure to use a pressure plate that is packaged together with a flywheel?  I already have the 1st flywheel mounted and was planning to stick with that. But now I’m not sure...and the first pressure plate has rust...fun
rdcyclist
rdcyclist Reader
10/24/18 4:43 p.m.
Dang, who's the vendor? I had a supplier that ended up shipping me 3 window assemblies for an interior shop door because they couldn't figger out how to package it well enough to survive a coupla days of FedEx mishandling without the reinforced glass getting broke. You know, they had ONE job and couldn't get that right...
Lof8
Lof8 Dork
10/24/18 5:08 p.m.
It’s an LUK kit from Summit.
Driven5
Driven5 SuperDork
10/24/18 5:16 p.m.
The clutch can be installed to the flywheel in any of three orientations.  If the balancing of the clutch were done in conjunction with the flywheel, there would only be one correct orientation and the other two would be very wrong.  Thus I would guess that any balancing has to be specific to the individual components.
dean1484
dean1484 MegaDork
10/24/18 6:02 p.m.
I haven’t bought anything from Summit in quite a while but I’m surprised the last couple times I purchased from them excellent service excellent packaging
Lof8
Lof8 Dork
10/24/18 8:13 p.m.
The flywheel has 2 dowel pins (off center) that only gives you a single orientation.
Edit:  I’ll look closer at that after work today.
Lof8
Lof8 Dork
10/25/18 4:12 p.m.
Confirmed. The dowel pins give only a single orientation of the pressure plate. I guess I need to find out if the flywheel and pressure plate are balanced together.
Lof8
Lof8 Dork
10/26/18 8:48 a.m.
LUK tech support says they are balanced independently so I’m free to mix and match. I’m hoping the 3rd clutch disk is not banged up.
j5WDiqZ4YyNaX4Y21jf3xQTgQEBDwOTz50lYolWEZY8IDKY4rG13jVmG3nS4hvYq
