mikeatrpi
mikeatrpi Reader
11/10/12 10:39 a.m.
I cut out the inner sleeve on my 280zx front control arm to install Energy Suspension poly bushings. However, they're loose! Like, I easily fit them in by hand and they wobble around a little bit. There was no way they'd fit with the outer sleeve still installed. I'm very confused - what am I doing wrong?
The instructions say not to cut the sleeve, but every single datsun web site claim the instructions are wrong and you have to remove them.
Now, I panic.
mad_machine
mad_machine MegaDork
11/10/12 10:57 a.m.
never dealt with poly bushings on a Nissan.. I know on my BMW they required some force to get in and do not move around at all
Copper280z
Copper280z New Reader
11/10/12 11:12 a.m.
All the poly bushings on my s30 were a tight fit, I don't remember if I had to ignore the directions for any of them or not, it was a while ago. They should NOT be loose though.
carguy123
carguy123 PowerDork
11/10/12 11:13 a.m.
The 2 piece Energy Bushings I installed on my 78 Z were not tight. They fit, without any wobbling, but they would go in and out easily with little pressure. I also put a zerk fitting so I could grease them regularly and I've never had an issue.
Wobble would make me think the bushing and hence the whole piece could move which would induce change.
11/10/12 11:34 a.m.
Yeah, wobble is definitely bad. Most poly bushings take a strong push to get them in. If they wobble, they'll do a good imitation of a bad bushing.
mikeatrpi
mikeatrpi Reader
11/10/12 11:35 a.m.
Thanks all. After a little more googling, it appears that I have the wrong part number... I need 7.3103 but I have 7.3107. Sigh.
11/10/12 12:06 p.m.
Energy Suspension is not good at getting all the right parts in the box, unfortunately.
mikeatrpi
mikeatrpi Reader
11/10/12 12:24 p.m.
Yeah. I noticed on my rear bushings (which fit snugly) one out of four inner sleeves is the wrong part. The ID is too small to fit the bolt. If I can't get Energy to ship me the correct part, I'll bore it a little on my lathe.
d0WvuOOHoIIK1BGVesTfH6Fl9xVIE1yV9GdyKmXebrDiTpg3SPl0kyZAzMcHd1Eb
