petegossett
petegossett UberDork
3/17/13 5:55 p.m.
I need to add a power lead so I can install the P2 brake controller into my '99 Chevy van, which has side-post batteries. I looked into tying into unused circuits in the fuse box, but none of the unused ones have terminals attached.
I tried(semi successfully) to connect under the side post mount with ring terminal, and it's working for now, but I don't have much faith in it. So what's the right/best way to tap into the + battery cable on a side-post battery?
zipty842
zipty842 Reader
3/17/13 6:31 p.m.
There should be a couple terminals on the engine bay fuse block.
Streetwiseguy
Streetwiseguy UltraDork
3/17/13 7:08 p.m.
I'm not sure exactly how a 99 G van will be, but if there is an underhood fuse block, somewhere on there , usually under a plastic cover, there should be a stud with the power feed from the battery. If its the older design, somewhere on the firewall there will be a block with battery power coming up from the starter. Inside on the fusebox, GM almost always has battery and switched power feeds . Often they will be piggybacked, with several wires coming off one terminal.
Failing those, there is always a stud with battery power on the back of the alternator.
Knurled
Knurled UltraDork
3/17/13 7:21 p.m.
While true, have you tried accessing the back of the alternator on a Chevy van? Not fun.
I would first go for the underhood fuise box stud, if the truck has one. It should.
If it does not, there's a not terribly pretty way to do it involving replacing the positive battery cable's bolt with a stud bolt. Auto parts stores do sell them in blister packs in the battery junk section. But... I've removed many of them from cars because they often suck.
petegossett
3/17/13 7:45 p.m.
Thanks guys, I'll try to find the underhood fuse box. I thought there should be one...somewhere.
Knurled
Knurled UltraDork
3/17/13 7:46 p.m.
If it's where I think it is, it's in a real F.U. spot in the driver's fenderwell. You need extended foreceps to remove a relay because there's no good way to reach a hand down in there.
curtis73
curtis73 UltraDork
3/17/13 8:12 p.m.
I use these:
It replaces the bolt in the cable and then has a stud on top of it. That way you aren't interfering with the flat connection of the cable ring on the terminal.
codrus
codrus Reader
3/17/13 11:24 p.m.
curtis73 wrote: I use these: It replaces the bolt in the cable and then has a stud on top of it. That way you aren't interfering with the flat connection of the cable ring on the terminal.
I hate side-post batteries -- my truck has them.
The stud ones work, but the downside is that you wind up with no really convenient way to cover the exposed +12 post. I've got a hacked-up brake cleaner can cap taped over mine. Ugh. :)
E4IrVJhGTqWOFx7mWJ8OSIdzfVL5A8lUeGgbEhZwlE0LQP3PDUUAFNjPewQVJxYG
